Hello.
I have a 340 GL, but I need some parts.
Can anyone help me? It's possible to send the parts from the UK to Portugal?
I need the following parts:
1 - front headlight (right)
1 - license plate headlight
2 - chock abservers to the trunk
I have another problem. The signal lights knob don't turn off, when I change the direction. It's easy to fix the problem?
Thanks.
Gouveia - C30 RDesign
Volvo 340 parts
Re: Volvo 340 parts
Indeed.alfa200 wrote: 2 - chock abservers to the trunk
Is that the pistons that hold up the rear hatch when OPEN?
Or the rear Shock absorbers (suspension)
Re: Volvo 340 parts
It´s the pistons that hold up the rear hatch.
Sorry my bad tecnical english.
Re: Volvo 340 parts
The tailgate struts should be readily available on Ebay. Isn't the rear number plate light part of the complete lamp assembly as these also appear on Ebay fairly regularly? The headlight may not be quite so straightforward as you presumably drive on the opposite side of the road to us and you'll therefore need a headlamp that dips to the right rather than to the left.
The indicator switch mounting is a common failure item and fairly easy to 'repair' by sandwiching the broken bit with flat washers - well, it's worked for me anyhow.
Ian
No Volvo 340 at present.
Re: Volvo 340 parts
Your english is very good my friend!alfa200 wrote:It´s the pistons that hold up the rear hatch.
I just have a very childish sense of humour, and I also wanted to make sure we were all thinking about the correct part.
links below!
numberplate light (aftermarket non-standard)
tailgate struts (expensive)
headlight
A couple of forum members are also breaking (parting out) cars currently, and they may be able to provide you with good condition used parts.
j360glt
Hope this helps.
And post some pics of the car please!
