Fed up with diagnosis... Replacing the lot!
Posted: 14 May 2010 08:27 am
by CBA
The whole front end's being ripped out and replaced, struts, joints, bushes, eyerything. Needs doing, most of it is original.
I've so far got:
STRUTS
INSERTS
HUBS (one is a bit suspect so i'm swapping them)
Front Wheel Bearings
BALLJOINTS
What I need are :
Strut top bearings (urgentish) used is fine by me.
Anti roll bar bushes (not urgent at all)
TIE rod bushes (need them in the normal sense)
Wishbone bushes (Oh my..)
W.H.Y.?
Re: Fed up with diagnosis... Replacing the lot!
Posted: 14 May 2010 11:57 am
Strut top bearing dimensions I measured the other day, give your local Timkin supplier a ring or go to the Timkin site direct, they have good catalogues on the website.
Images approaching...
Check what condition your top spring cups are like first though,
They are mostly like this and cracking.
I'd talk to some suspension people, they will be fairly universal. The dimensions are all on my photo thingy but save abusing this thread I'll just post:
If you get a new top cup, just get a different sized strut top bearing that still has the same inner dimension to snugly fit the damper shaft.
Right, onto bushes. Dai will do you wishbone bushes in poly. They arn't a huge amount of pennies and are available unlike the originals ;) Tie rod bushes, again, Dai. Antiroll bar to wishbone Dai also does, but anti roll bar to chassis as you've got a 1.4 (I think...) he doesn't do, he only does 19mm ARB and above for that. Best chance there would be to ring up superflex I'd imagine with the dimensions as I'd imagine it's the same as something else.
I've just installed a set of front end ones, all the above piccies and a million more are http://www.flickr.com/photos/c_cardwell ... 229120615/ if it's any help to you.
Posted: 14 May 2010 05:23 pm
by CBA
Excellent!, I have till january to get it sorted, looks like I might be ready for middle of summer tho given this wealth of info - Holland or BUST!.
Thank you V Much! sm4
Posted: 14 May 2010 06:16 pm
by CBA
So the strut bearing only needs to fit the damper shaft, and the cup then is to suit the new bearing and accept the spring top, so mix and match.
got it.
I get the struts soon, so I'll get new springs for them also and rebuild them off the car, makes it an easy job then, one out one in.
So wishbone + tie rods first.
Posted: 16 May 2010 08:05 am
by CBA
Deleted
Posted: 16 May 2010 08:43 am
by CBA
Just these few unnacounted for,
suspension spring cups x2 :roll:
Wishbones
Shock absorber dust covers/gaiters --
that is all.
Doing bloody well I think, pat on the back to contributors! :D
Think I deserve a rest, been searching parts for about 9 hours... no 11 :shock:
Will put up a list of saved volvo part URL's, I found a few...
Are there any parts at all I've missed out from front suspension that would likely be worn?
These are what I'm getting so far:
OEM struts (used but solid and tidy looking, can be smoothed and painted to look brand new easily) £30 + delivery
OEM inserts (very lightly used, will service them as shown in the manual) (included in struts)
Lightly worn OEM hubs (included with the struts)
Bottom Ball joints, unsure of quality, they look "advanced" tho, solid/refined. £9.90 + delivery
Top strut bearings (sourced I think. check the link) ---> http://www.teiledirekt.de/product_info. ... 57/refID/2
Spring cups (NOT sourced, anyone know where I can get these illusive little buggers)
NEW springs (can source but theyre a tad expensive, any cheap places?)
Tie rods (either rubber or poly - apart from longevity what's the ride quality difference, I can source both kinds easily)
Wheel bearing kits Left/Right (sourced, about twenny quid delivered)
Steering rack gaiters (£5 each or so)
Anything I should add to that list :?:
Anti roll bushes are in fine condition
Radius arm bushes are also fine
steering rack/track rods etc have no play, all joints/mounts concerned with steering are solid with no play detectable.
Posted: 16 May 2010 10:27 am
by Edcase 300
well done on the progress dude looks like youve been mega busy! sm4
Posted: 16 May 2010 11:17 pm
CBA wrote: NEW springs (can source but theyre a tad expensive, any cheap places?)
Just a quick post as I'm skimming atm, will try and read through properly later.
Either Dai along with the bushes, or Falkner's Springs in Portsmouth. Both are around £60 for a pair (I'm not exactly sure obviously ;)) and will custom make them to spec. The green books list these.
As to bushes, do the lot whilst you have it apart. It really is false economy not to. I run polys and have noticed no more uncomfort, Dai's are at the "lighter" end of polybushes and are still comfy as.
Posted: 17 May 2010 03:05 am
by CBA
i think i'll leave the one or two bushes that are good, they look new, and are easy enough to replace with poly bushes later, it's only a few left behind for time being, I dont mind replacing them later just they're solid and servicable for now.
Spring cups, i have a phone number... ring tomorrow :) .
those dust protectors for the struts, still no luck. :( , I mean theyre not important but these ones I have are all floppy and ugly.
I know they're pretty universal but I want a snug fit...
