Low oil pressure - sorted
Posted: 25 May 2010 10:55 am
by pyro
Hey folks
SO new engine in, very impressed with it, very smooth and quiet.
However on the over-run/engine breaking to a round about the other day the low oil pressure light came on. It stays on under circa 1400 rpm, or it did, on a test yesterday the rev range it went out at was getting higher and higher. now about 2200 rpm
So tow truck on the way, will be home in an hour or so.
Im hoping it will be somthing simple like a fecked pressure switch, or ive not attached the pump properly.
I do have the 940 engine pump still, is it possible to swap the oil pick up pipes round? as obviously the 360 and 940 are way different?
what else could cause it?
synical sven said regrind and re-shell
however ive had a good few weeks and refuse for it to be that!
Ben
Re: Low oil pressure -
Posted: 25 May 2010 12:05 pm
by Speedy88
There was a topic here recently where it was just the return spade was corroded - just check this out first
Posted: 26 May 2010 06:36 pm
by sven360
pyro wrote:Hey folks
Realist sven said regrind and re-shell
Ben
Fixed that typo for you Ben,ol' bean.
If it ain't summit simple like blocked p/up or failed o/pump it'll be as previously stated.
010" grind for the win.
Or, if it's really badly scored 030".Bigger the grind,more ya pay.
Or run it for as long as ya can until there is a catastrophic death rattle and then do the job properly.
Best join the AA mind ya.
Posted: 26 May 2010 10:08 pm
by CBA
Contaminated oil, (leaking head gasket)
Old oil.
Worn pump.
Blocked pick up pipe.
Blocked oil filter.
Clogged oilway to/from oil filter.
SLudge.
defective pressure switch.
Defective pressure switch wiring.
Bad crank bearings.
Bad cam bearings.
Leaking hydraulic lifters
sorry which engine... allow for mistakes.
Posted: 26 May 2010 11:23 pm
by pyro
cheers for that cba!
its a volvo 940 b200 (1995 ish)
the wiring all looks ok, as it goes out when reved. however it will all be checked!
i have a spare pressure switch that il lswap in when i get home.
theres no smoke at all from the exhaust so dont think its the head gasket
ill see how things go when im back
thanks!
Ben
Posted: 30 May 2010 11:32 am
by pyro
right found the problem
the oil feel pipe has a little orange/redish seal/oring that sits the the block right?
well its not, well not all of it anyways!
hoping the 940 one will be a direct swap.
Ben
Posted: 30 May 2010 01:59 pm
by pyro
i fixed it!
40 mins to get the oil pump, sump, front cross member bolted up and torqued i recon is good going!
pressure light now goes off at cranking which is how it should!
Ben
Re: Low oil pressure - sorted
Posted: 03 Jun 2010 05:25 pm
Where does that go then? It looks just like the seal for the turbo oil return pipe that fits from outside the block.
Posted: 04 Jun 2010 09:28 pm
by pettaw
it fits round the output tube of the oil pump. There's an O-ring at both ends, where it leaves the oil pump and where it enters the block.
I think I remember reading about it somewhere might have been the 700/900 maintenence FAQ...so it must be a very common fault on redblocks.
