where are going the vacuum's tube??
Posted: 30 May 2010 05:34 pm
Hello all!
I have a problem with my 340 . I would like to regulate the mix and the idle speed...but some of my vacuum plug are note connected. I have a b14 4s motor from a 1894's GL. A swiss edition.
I have those commands:
-EGR vacuum command ( return of the exaust gaz in the admission).
-Pulsair vacuum command ( which give some 02 to combust C0 and NOx next exaust valves).Pulsair is correct plug in the air box, it's just the command
-intern tubes in the carbu wich is not plug in.
-vacuum to change the ignition's timing.
-from the oil vapor (like a command too)
I have thoses plug:
-On the reheat flange
-back from the carb (I think it's for ignition).
I have study the book, but I haven't find how to fix the tube
I will put some pics in the futur.
I have thoses plug:
