CD radio installation
Duvel78
Website Admin
Post by Duvel78 »
Message from Chris (Germany)
hi guys,
i've got a question-i've bought a new cd-radio for my volvo 340 and i don't know how
to intstall it. the radio has an iso-plug on its back. can you help me in some way?
greetz form germany
chris
V3M for life!
5lab
Post by 5lab »
think you can get an adapter - try a normal car hifi shop.. you'll need a facia adapter too.
mines got a cd changer in it but i didnt install it so i dunno how the wiring is done
Lonewolf
Post by Lonewolf »
If it mounts the same as from a 360 then you need to pull the glovebox out to get at a hard to reach screw holding the back of the original unit in as well as the wiring. I did mine a while ago, so cant remember all the specifics, but you had to access the wiring and mounting screw(s?) from through the glovebox. Hope it helps
Post by foggyjames »
The later ones didn't use the rear screw I don't think...although I'm not sure...
Foggy's right, I didn't need to do anything that compicated with mine, pop off the covers either side of the orig volvo unit, 2 radio keys in, unit out. Autoleads harness -> iso adapter on, cage in, new headunit in.
I didn't need a fascia adaptor either!!!!
I've found you tend to need to enlarge the stock facia slightly (like 1mm all round), as the Philips / Volvo HUs are very slightly under DIN size.
5lab
Post by 5lab »
it was fine for mine mate, perhaps its just your stereo??
Swapsea-'89 360GLT-swapped!
This has been the case for two head units now...first a Kenwood, now a Pioneer. Isn't yours lacking its 'cage' anyway?
5lab
Post by 5lab »
yeah but surely the cage would be behind the entrance to the facia anyways?
There's a lip on the front of the cage which fits into the outside of the frame.
