Speedo stopped working..read
Ok so after i fitted my suspension i noticed that my speedo was not working. I have have a quick look in the hub and in the back of the clocks and they both seem like they are in properly. Need to have a better look at the hub end. However since putting the damper new damper in, and taking the old one out, means that you have to lower down the actual hub down on the lower arm maybe it pulled and stressed the cable? I did notice a couple of times that the cable was being pulled down a bit while we were putting in the damper. All i can think of is that it has pulled it a little to much since it was working fine before we put the suspension on. :/
Any help would be appreciated, Thanks
Ben......
Ben......
Re: Speedo stopped working..read
has it still got the rubber stoppper on the end that holds it snug in the hub
Attack2001
Does it still have the little metal circlip on the end of the plastic bit? Thats the main problem...
Thomas................
It still has the rubber thing on the end holding it into the hub but i am not sure about the cir clip :/Attack2001 wrote:Does it still have the little metal circlip on the end of the plastic bit? Thats the main problem...
Ben.....
Attack2001
If you've lost the clip, mac can supply new onesBenfraser wrote:It still has the rubber thing on the end holding it into the hub but i am not sure about the cir clip :/Attack2001 wrote:Does it still have the little metal circlip on the end of the plastic bit? Thats the main problem...
Ben.....
Thomas........
Where a bouts is this clip?f you've lost the clip, mac can supply new ones
Thanks, ben......
Attack2001
Look in the centre of the front left wheel, you should see the centre/oil cap. The clip should be around the square plastic bit on the outside:Benfraser wrote:Where a bouts is this clip?f you've lost the clip, mac can supply new ones
Thanks, ben......
Spares in this thread:
http://www.volvo300mania.com/forum-uk/v ... =8&t=13193
Thanks, Thomas......................
Ok thanks i will go and have a look at this clip in a bit and will let you know
ben......
ben......
I have just looked at it and it appears to be ok? Also here is the actual cable that goes into the back of the hub..Look ok? Thanks, any help would be appreciatedAttack2001 wrote:Look in the centre of the front left wheel, you should see the centre/oil cap. The clip should be around the square plastic bit on the outside:Benfraser wrote:Where a bouts is this clip?f you've lost the clip, mac can supply new ones
Thanks, ben......
Ben........
Attack2001
Nope, grab hold of the cable, and push it into the back of the hubBenfraser wrote:I have just looked at it and it appears to be ok? Also here is the actual cable that goes into the back of the hub..Look ok? Thanks, any help would be appreciated
Ben........
Grab what part? The part in the photo and push it in to the back of the hub?Nope, grab hold of the cable, and push it into the back of the hub
Ben.......
Attack2001
Yup the big cable in the pic, push the throttle cable into the back of the hub. It looks like its been pulled out the back.Benfraser wrote:Grab what part? The part in the photo and push it in to the back of the hub?Nope, grab hold of the cable, and push it into the back of the hub
Ben.......
**** Speedo cable
Yeeeeees! Fixed it :p
Ben........
Ben........
Funny looking throttle cableAttack2001 wrote:Yup the big cable in the pic, push the throttle cable into the back of the hub. It looks like its been pulled out the back.
Attack2001
Ah buggermacplaxton wrote:Funny looking throttle cableAttack2001 wrote:Yup the big cable in the pic, push the throttle cable into the back of the hub. It looks like its been pulled out the back.
P.S Glad to hear it ben
