INDICATOR-STEM MOUNTING HOLE CRACKED?
The lower plastic hole that locates/holds my indicator-stem has cracked. Im guessing there's not a hope in hell that superglue will work to replace the part thats cracked off? Also the top screw seems loose; It seems in order to do it up I need to remove the steering wheel plus the speedo fascia?...
1988 340 1.4 DL
- 340GLT
Re: INDICATOR-STEM MOUNTING HOLE CRACKED?
Its a common fault your best bet is to use a small strip of metal across the bottom from the wiper stalk to replicate what the plastic used to do.
Thanks adam; Im guessing that entire bottom strip of plastic is removable then? Gonna have a crack at it tomorrow...
1988 340 1.4 DL
No keep the plastic in place. The metal strip is just to brace the plastic from one side to the other
Not the best picture but something like this is what you need to do
Thanks Dai, that is a great help...
1988 340 1.4 DL
Hi Justin
Piano Hinge works
Thats how i fixed mine.
Piano Hinge works
Ive used a metal repair bracket which I had to cut to the correct length and drill an extra hole. The side that has the earth wire just about takes the original bolt!
I've put blue locking-compound on all four bolts to hopefully stop them working loose again...
1988 340 1.4 DL
