part numbers??
thejackal01
part numbers??
Post by thejackal01 »
can I get hold of part numbers for the 340 at all. there is only one part I need to get hold of now, but not having any luck and need it asap.
this is for the kickdown switch.. trying to see if I can get nos or alternative part
many thanks
Re: part numbers??
Post by macplaxton »
As may have been mentioned before. There is no part number for it as it is part of the throttle cable on both manual* and automatic cars.
throttle4 by macplaxton, on Flickr
*manual cars have the same cable but the earth interrupt is not used.
thejackal01
Re: part numbers??
will a new cable come with switch?? or is just the cable?? as manual will not need kickdown ?? or am I just taking out of my ...... well ..you know :D
Re: part numbers??
See the last sentence of my last post?
...and what is shown in the pic.
You get the inner/outer whole cable assembly from nipple to nipple. If I remember rightly, Sion posted some pics up whilst I was away. :wink:
thejackal01
Re: part numbers??
well may as well try a new one .. any idea where these can be found. lolcal stockist out of stock or do not list them
Re: part numbers??
thejackal01 wrote:well may as well try a new one
Well that's going to be hard work unless you have one handy.
Given that it's now over 20 years since the last one rolled off the line, I suggest you go back to testing and eliminating, rather than changing everything in sight. Because changing everything in sight is a sledgehammer to crack and walnut. It's also tells you zero about what the problem is. Costs a packet. Some parts are made of unobtainium, so it'll be second-hand or nothing. Second hand parts may/may not be working either.
