'How to Guide' How to fit a 140MPH speedo
Post by foggyjames »
The driving computer gives an almost perfect speed read-out, which (since it's set from the trip meter) goes to show that the over-reading is needle-error, rather than the mechanism as a whole being bad.
Post by classicswede »
I've borrowed my dads road angle and that indicates that the 440 spedo is reading just over 10% slow and the original is runs about 10% fast.
I think I will get the 400 one recalibrated to the correct speed now I know exactly what it should read.
If I had stock wheels and tyres it would probalby read spot on.
BMR
Re: 'How to Guide' How to fit a 140MPH speedo
Post by BMR »
Topic kick......
I used this guide for the speedo change in my 360turbo.It's realy a piece of cake.....if you don't do anything anything else......
Testing showed a diference of about 3 KM/H negative which is ok(tested with a gps) .Probably due to to the bigger wheel diameter.
Impossible..................is a challenge
It is a good upgrade and saves running off the end of the speedo a lot of the time :lol:
Post by 340GLT »
That brings back memories!!
BMR
Post by BMR »
340GLT wrote:That brings back memories!!
Wanna talk about it? :)
Joe Danger
Post by Joe Danger »
JUST !
Be careful about using "the fork trick".
I've changed the dash light in my brothers honda (adding 26 LED's inklusive the normal ones on the back), and used the fork trick.
- but it damaged the rev needle motor, so now it's fucked...
- easy fix tho.. but annoying money...
Why "Joe Danger" ?.. well I allways imagine a japanese drift speeker screaming it "DjooooooeDjeeeenDjaaaarh !!!"
... and then i smile
Post by MCHUDD »
Hi all
That turbo 360 just looks a CLASS ACT.
sm4 sm4 sm4
