1985 Volvo 340 B14 Variomatic to 360 B200 Manual
A couple of days ago i got my 340 that i have been wanting for a while, and it came with a 360 donor with a redblock on it, how difficult is/ can the swap be?
Re: 1985 Volvo 340 B14 Variomatic to 360 B200 Manual
Very doable but you may have to use the 340 mounts for the gearbox and get creative with the mounting holes for the engine brackets. I'm not 100% sure if the redblock fits under the standard Mk1 bonnet, you may need a GLS/DLS bonnet.
Hi,
If this thread is still going, can you take a pic of 360 gearbox mount?
I have this Volvo part number 297635 which bolt onto gearbox then I guess mount onto the body.
This item should have 2 bolt holes but looks like melted away and massive crack.
I guess I could just make steel bracket to replace with rubber bush but it will be good to see what original was looked like.
Atchi
Atchi
