camber adjustment on a 340
silvia
Post by silvia »
is there any way i can get plenty of negative camber on the front of my volvo and possibly put some positive on the rear? i ownly ask as mine looks the wrong way round, loads of negative on the back and the front is sort of standard
regardes
matt
Frits
Post by Frits »
I should not reccomend positive camber on the back. Keep it original, or go for zero.
You can place the front swingarms more outside to create negative camber on the front. You need to modify the subframe like they do in the dutch racing cup. However, there are more ways to go for.
IvanAE86
Post by IvanAE86 »
Frits's suggestion is the easiest way to go about it.. drill new holes for the front control arms in the subframe right at the outer edge, then weld some reinforcing plates around the holes to keep them from tearing. This gives you about 3 degrees negative camber (which is more than you would like on a streetcar, but you could always move the new holes a bit to the inside).
Another option is to try out some camber plates from other cars and make them fit. I suppose RWD escort ones might be worth a shot, japanese stuff might come close too (I have some corolla AE86 ones I would like to try out once). It could be as easy as redrilling/threading a hole here and there, and presto..adjustable camber.
silvia
Post by silvia »
IvanAE86 wrote:drill new holes for the front control arms in the subframe right at the outer edge, then weld some reinforcing plates around the holes to keep them from tearing.
has anyone got any pics off this so i could see it and understand it better. i am a welder buy trade so im not worryed about the work i just want to get it rite first time when i do it.
thanks for the replies
regardes
matt
Jason B
Post by Jason B »
I'm also interested in a few pics this, just to see what people have done.
Post by classicswede »
Adjustable strut tops would be a help.
Frits
Post by Frits »
regardes
matt
Never seen any pictures.
But it is a very simpel thought. Imagine the hole a inch (for example!) more to the right.
I'm gonna do this to on my driftcars
