Page 2 of 2
Electrical gremlins-soon to be...(with added lack of initiat
Posted: 28 May 2010 08:15 pm
by Edcase 300
That makes sense. The starter and such works-with the Ht leads giving good spark.Im thinking that its likely to be either Red wire from the Fuel Pump to the Fusebox or The Red one the other side of the Fusebox.The aux fusebox needs sorting-which im going to do too.What i don know its that the LE Jet relay is working as i got dad to test it and pretty much most relays in the car.
I just want her to work again
Re: Anyone good with electronics/solving electrical Gremlins
Posted: 31 May 2010 06:00 pm
by Edcase 300
Right...I got my ass in gear and undertook some investigative work which has brought about some good news and some Sh!T news....
Im scratching my head...after cleaning contacts etc,new (and correct) fuses,and testing the most obvious bits with a homemade test light (zener diode + led combo)... grrr my fuel pump works
BUT..
my fuel pump is pumping fuel even the igniton isnt on (just battery connected) i.e im not cranking the starter,no key in ignition!
im ever so slighlty irritated & i know im a numpty but... does anyone know what might be the cause of this constant pumpage?
Again any feedback muchly appreciated.
Posted: 31 May 2010 07:10 pm
by Edcase 300
I reconnected everything as it was before the vehicle was running.Only difference is that the fuses before were wrong rating.Now has right ratings and contacts are clean.My problem is that the fuel pump runs even just by connecting the battery & without the key in the ignition.
Help much appreciated-pretty annoyed with Vulva & the numpty who owned her before me tbh
Posted: 31 May 2010 07:41 pm
by volvodspec
did you disconnect the wires of the fuelpump relay?
what does the fuel pump do if you prime it by key?
Posted: 31 May 2010 09:06 pm
by Edcase 300
hey thaqnks for the reply
i didnt try those.
im going to try priming it by key (in theory should work now)...
i think i know what you mean about the fuel pump relay wires -maybe there was some kind of short in the wires? i will test the wires...
(the relay its self seems to work-i got my dad to test a whole load of relays from the car (all which seem to work after testing).
cool so i'll try that & let you know if i find something.thanks for the help-im really new to all this
Posted: 31 May 2010 10:42 pm
by Edcase 300
Hi again
I jiggled the fuel pump relay and primed the ignition with the fuel pump in... the fuel pump is working.(I got dad to observe the fuel pump as i pu the ignition on..i quickly got under the car and heard the pump buzzing... then turned the ignition off... lolz
BUT it decided to keep on pumping without the key in (again) ..so i had to quickly disconnect the fuel pump wires
I disconnected the vehicle battery & put it on chatge to spare it but Im going to test the wires that go to the fuel pump with my homemade testlight when i next get a chance.. it seems very odd
Re: Anyone good with electronics/gremlins-now with pics..RE-
Posted: 08 Jun 2010 07:44 pm
by Edcase 300
Rebump on old thread...
The blooming hose (above) was not only loose but also filthy.. does anyone know what it does & ist effect if not coonnected properly?
Below pic is of a Broken battery terminal
lolz
and below...(fuses replaced with correct ones (according to v3m wiring pdf) & contacts cleaned... (i wonder if its correctly connencted?
The test lamp (zener diode & led) home made thingy (dad made me it ofcourse)
Blooming car...any thoughts appreciated
Posted: 09 Jun 2010 12:31 am
AFAIK the fuel pump is only driven from the control relay, pull out the fuse and the relay. Then put them in one at a time. That might tell you something. If the voltage is coming from the relay and it only goes when it is in then the relay is faulty or incorrectly wired.
How do you know the relay is working properly? It would be a complex test to check it properly.
Posted: 09 Jun 2010 10:45 pm
by Edcase 300
Im going to have a try at that ... see what happens etc.
My dad tested my relays for me (im not smart with electrics unfortunatley tbh)-im not sure what he did exactly...
Problem is the vehicle's electrics were never great when i got it 4 yrs ago.. just seems odd that the car stopped working then after cleaning out contacts, putting correct fuses on fuel pump and so forth it now has the weird pump problem.
Im thinking it might be the wiring to the fuel pump relay (imean the loom under the relay) or maybe something to do with the ignition switch? mmm
URL=
http://s976.photobucket.com/albums/ae24 ... usebox.jpg]
[/URL]
These fuses weree on the fuel pump fusebox before
Completley wrong rating according to V3M Wiring PDF.. and im assuming they were buggered as when i put in the fresh + corerct fuses in the pump worked from the ignition. Crazy though aas if fuse goes then circuit is no longer complete right?
Posted: 09 Jun 2010 10:53 pm
by volvodspec
yeah and i still wonder what happens with the fuel pump if you start it/ run the engine
it could be that the pump is then off wich would indicate that the relay is wrong wired and rewiring it solves the problem
Posted: 09 Jun 2010 11:15 pm
by Edcase 300
i miss read your last posted post man.
i havent tried starting the engine with the change of fuse... so i will give it a go during the wkend... might well be that it doesnt start (wouldnt surprise me tbh).
Posted: 06 Jul 2010 03:49 pm
by Edcase 300
(Thread RE-BUMP)
Rightyo- my oldman wont let me start her and i dare not argue with him
Im really not sure what the hell my dad did when 'testing' the relays but it seems odd that the wiring would be wrong...
Would i be correct in stating that the relay completes the circuit from the battery side + ignition side Red wire , to the relay (circuit switch) to the other Red wire in the loom which then goes to the fusebo, (through fuse) to red wire to fuel pump?
Only thing i can think of after numerous mini study sessions at the wiring diagrams is that the relaay is screwed?
The relay controls the whole Le-jet system... thing is if the relay switch circuit was stuck closed then that would explain why the pump is on (testlight in situ in place of relay permanently on... when fuse if taken out circuit is incomplete and its not on.
(do tell me if im correct or incorrect-it sounds mega obvious but im a noob with this type of system)
If what im thinking is correct then im guessing i need a new LE Jet relay? If so-does aanyone know where/if i can still get this part? How much a new one costs?
Things are getting done know at home- as my parents will need the other 2 cars to get to thier work and i need Vulva to get me to work -
As always thanks for the help guys and patience btw im still very nieve to all this
(lolz and yes i am slow with technical stuff-im the arty type (excuse) lolz
Re: solving electrical gremlines *now with added hope...(wel
Posted: 07 Jul 2010 10:36 pm
Yes could be the relay. It is supposed to switch on the pump when there are pulses from the flywheel sensor, so that if you crash and the engine stops the fuel pump doesn't continue.
If you are sure it could not be wired incorrectly then take out the relay and smack it on the ground a few times, that might free it but its a long shot and it might happen again. I should have one spare if you need it, PM me with address and offer. As a bodge you could wire in a manual switch but it would be not crash safe then.
Also don't worry too much about the pump continually going when testing, the fuel is a full return system, the fuel will just flow back to the tank if the injectors are not switching on. There is a mechanical pressure regulator that keep the pressure in the fuel rail constant(ish), surplus fuel just goes back to the tank.
Posted: 09 Jul 2010 08:02 pm
by Edcase 300
Hey thanks for the offer
I will PM you regarding the Relay-er
