Horn won't work - Desperate
kelvingenders
Post by kelvingenders »
Could anyone show me a picture (preferably colored) of the connections going into the "black plastic that sits over steering column". This has two connectors. I really need to know, cause I'm finding that when I try to connect this up to wire i think could be correct....
a) the horns don't work
b) the wires get bloody hot
All of which tells me I'm not doing this correctly
This is for a 360 GLT B200EA model (MK3 ) Australian
Can anyone help with a picture?
Kelvin - Brisbane...The only man in Queensland to own a 360GLT :360: :360: :360:
Re: Horn won't work - Desperate
Take your steering wheel and dash surround off until you see something like this:
See those 2 pins poking out just above the steering column? Stick a screw driver over those. Basically the horn push just completes the circuit for these. If that works then it's probably a contact problem between that and the horn ring or within the steering wheel itself.
Edit: Re-reading your post it appears you've already got to this stage :lol: Find the wires going into the back of these pins? I seem to remember one being purple but I'm not too sure...
kelvingenders
Already got to this stage, I need to know which wires go the the wires attached to the black collar which sits on the steering column.
Thanks Kelvin
kelvingenders
Horn is now fixed..looked for more wires and trialled and errored - it now works
Kelvin-Brisbane
Winner :)
kelvingenders
looked at length of potential wires that could fit and Dual horn is rampant
just for reference, its normally a pink wire and a brown wire you need. Glad you fixed your problem Kelvin.
