Bosch Feul pump electical connections
Evoman
Post by Evoman »
I am in work atm and the car broken down. Does anyone know where the ignition module is? On thee air flow metre? Help asap please
http://shop.ebay.co.uk/i.html?_from=R40 ... Categories
Nimminz
Re: wheres my ignition module?
Post by Nimminz »
In front of the passenger side strut, between that and the battery. Its the renix unit and has the coil attached.
Evoman
Post by Evoman »
Cheers, this?
doesnt look the same as the ebay pictures :/
The broke down this morning, it cut out at the lights and wouldn't restart, it then started after about 5-10 mins. It cut out yesterday aswell but by the time I pulled over It would restart with some throttle. It has been running alittle lumpy seemly randomly. Any ideas what it could be?
It was suggested it was the ignition module but I know have alittle more time to find the fault
thank you!
Evoman
Post by Evoman »
Dash lights were on, and after a while i could spell petrol, so i assume there no spark?
Nimminz
Re: wheres my ignition module and is this is right one on eb
Post by Nimminz »
those on the ebay link look similar to the connector on the air flow meter.
How new are the plugs (and are they gapped correctly)?
How new are the leads?
How new is the coil?
How new is the rotor arm?
Check the distributor cap
Plus clean the MAF
I had problems with mine misfire-ing and running rich and it turned out to be a combination of all the above. Mainly the rotor arm. If it restarted after a bit i'd suggest checking them first.
Evoman
Post by Evoman »
oh, i've just the parts now. I do think its them though because it seems to be something heating up.
dizzy, plugs and leads look farely new (i know its not alot to go on) but the coil looks bad so i've odered a new coil and module. Ill check the rotor arm, plugs etc when tommrow as well then :)
Nimminz
Post by Nimminz »
aye, coil helped a lot on mine. rotor arm was the last thing i changed and made the most difference. I've renewed the lot and have a 'high performance' coil lead to pick up in the next few days.
It's never going to be bad renewing parts.
Evoman
Post by Evoman »
ye, id happly replace them all bit its money. Ill take the rotor arm off a see if i can clean it up
Nimminz
Post by Nimminz »
aye same here did mine over a few month lol
The renix will be fine, in 10+ years of mucking around with countless 300's I've never seen one fail. The coil bolts on the front of it, those connections can corrode. Other things I'd be suspect of would be the crank sensor, but if it's not been serviced Nimminz is right and the dizzy cap and arm will be loosing you MPG at pace.
I take it you've checked for spark?
Evoman
Post by Evoman »
Its an intermitant fault, so I can only check more things when it breaks. it suggests to me that its something getting hot and stops working. My lgoic is that the ignition module is most likly to be effected by heat. but why is is getting hot, either coil is getting to hot or the acctually module is
Evoman wrote:Its an intermitant fault, so I can only check more things when it breaks. it suggests to me that its something getting hot and stops working. My lgoic is that the ignition module is most likly to be effected by heat. but why is is getting hot, either coil is getting to hot or the acctually module is
My money is on the cps, maybe dizzy cap/arm
Evoman
Post by Evoman »
Chris, why is your money on it?
Ignition module was suggested by my preivous boss too. My plan is on sunday to try and run it till it cuts out, then test the CPS
Would a dodgy CPS stop it from starting though? I would expect it to start, then misfire alittle or cut out.
Evoman wrote:Chris, why is your money on it?
Most garages love blaming renix units, on most 80s cars electronic ignition was unreliable but the renix (as much as its French and this pains me to say ;) ) is a very well engineered bit of kit, I've never seen a unit fail. I had a box of "non working" ones from a garage once, each was fine.
Cps failing with heat is something I'be seen time and again, as well as with water. They run fine cold, but then when you either get the engine hot from heavy use (mine was on track and rallying) or through fords she'd either run lumpy or cut out completely. When they cut completely you have no spark so easier to check but often they'd cool down and by the time you had the spanners out it was back to running again!
Evoman
Post by Evoman »
Ah! that sounds like what is happening to be me, but its not when im ragging it, just driving normally. There are none on ebay :(
