late 80's 360glt wiring. run away!
Logan360
Post by Logan360 »
Hi all have an '87 with towbar and a/c going into '86
have come across wires which i am stumped as to there use.
I can't do pictures sorry
have a pair of wires which come from second fan
a pair which come from an addition into the top radiator hose
a pair from under the throttle body.
they all head over to a loom and relays by the battery.
this loom then goes from there in front of heater where
a black wire runs off to yellow/red from engine loom
the rest carries on to fuse box area where
a blue shoots off under the heater
a blue and a green go in behind heater on side
and a white/black plugs into a w/b from fusebox
can anyone help with this?
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
Re: late 80's 360glt wiring. run away!
You really need a manual or wiring diagram, or you are going to have to ask simpler more specific questions. Wiring is hard at the best of times.
Logan360
Post by Logan360 »
I have a feeling its al towing related. if anyone has the auxiliary fan in their car they should know which wires i mean. theoretically. the haynes manuals say that fan is a towing option, hence assumption.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
