part number for kick down switch
thejackal01
Post by thejackal01 »
looking ti buy one for my 340 vario as found to be faulty... can anyone help with a part number maybe so i can do some internet searching for one please?
many thanks
Re: part number for kick down switch
Post by volvodspec »
then you probably need a new throttle cable...
for the time being take the yellow/green wire mounted to the kickdownswitch and make a new wire to it wich is connected to a earth, that will get you driving without high rpm's... for overtaking simply press the low gear hold switch for the same effect.
thejackal01
on my car it is brown wire??????? this is the connection on the bulkhead where the cable runs through the middle ???
you need to look in the cabin, above the gaspedal; there is a contact with the yellow/green wire; that's the one you need to ground
thejackal01
oh right. so leave the one on under the bonnet.... sorry didnt know that... will give it a try and then see if i can get a new cable and switch.
thank you for your info. wikll follow up after i done it. thanks :D
This might help you out:
throttle4 by macplaxton, on Flickr
Maybe you have a clip missing? Maybe that end of the cable could be disassembled and cleaned up? Sorry can't remember everything (I've just got up! sm1 )
