WANTED: Volvo 360 rear axle
I am after a rear axle with the rotating assemblies on each end. The brake parts and brake drum are not required, just the axle and stub axles.
It is to be fitted to a 1989 360 GLT.
What have you guys got?
Re: WANTED: Volvo 360 rear axle
I would say mememememe!! i has 3! but i priced one up a while ago and it was a ridiculous amount for freight.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
If i orgnaised freight then how much do you want for one?
Cheers,
Andy
Cheers,
Andy
I think freight for one was £60 from new Zealand to England.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Just went through my messages. postage on 3 was £200 so you'd be looking around £65-£70 for freight alone.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Oh, I didn’t realise you are located in NZ! Either way, do you have a weight so I can get a quote?
Also, how much do you want for the axle itself?
Thanks,
Andy
Thanks,
Andy
I think from memory its about 6kg. and i don't have a price in mind. i usually get a postage quote and figure out a fair price once that's done, so it doesn't cost someone the world. but just checking, your after one half shaft, up to and including the "cv" joint with 8 bolts on each end?
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Sorry, no I'm after a complete axle with stub axles, cv joints etc on each end.
I think we've crossed wires here.
So does anyone have a complete axle?
Oh you mean the solid rear bar? one piece. hollow tube?
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
If you don't mind me asking, How did you manage to break a back axle?
I haven’t broken the axle. I have tried to replace the RH rear wheel bearing and can’t get the cv joint outer half off the stub axle. The strongest 3 legged puller I could buy has failed to get it off.
I need to do the wheel bearing on the LH side aswell and as it is my every day car I can’t have it off the road for long.
The plan was to recondition a second hand rear axle with new bearings each side then fit this to the car as a unit.
Does anyone actually have one for sale? There has to be a scrap 360 some where with an axle that someone would sell?
I presume you are talking about the drive flange, that the CV joint bolts onto. Hope this is not a stupid question, but did you remove the big retaining bolt from the middle? I think I tend to use a 2 legged puller, a 3 legged one that fits is not strong enough. Its not usually that hard.
Why do you need the halfshafts + CV joints?
If its really stuck, would it not be easier to destroy the whole hub and cut it off and get a replacement for that.
I have a 340 one with good bearings but i am in Belfast.
I dare say the axle is the same although the brake asembly
is different. Postage would probabley be a killer though
Not quite as simple,
340/360 Axle, Rear Wheel Bearings,Flanges, Shafts
340 to 85, 340 86 on, 360 to 85, 360 86 on,
Axle beam 3208483. 3208483. 3294693. 3208484
Bearing housing 3291348. 3208044. 3294697. 3208044
Bearing 2x 3105765. 3411886. 3294713. 3411886
Short shaft 3266293. 3245853. 3208432. 3245853
Inner flange 3298347. 3208251. 3294759. 3208251
Flange nut 3103060. 3294865. 3294865. 3294865
Brg.seal inner 3296234. n/a 3294834 n/a
Brg.seal outer 3202798. n/a n/a n/a
Brg.housing bolt 963900. 959242. 3270229. 959242
Brg.housing nut 963921. 971089. 963921. 971089
As you can see it's all down to year and model! - at least two beams, three bearing housings, and three inner
flanges!
Mac.
flanges!
Mac.
Re: WANTED: Volvo 360 ('86 on) rear axle
Ok, Thanks for clearing that up. Title changed.
I need just the axle, and rotating assemblies of each end minus half shafts. Or if someone has a rotating assembly and hub off one end for sale then i'd also take that.
Long shot, anyone got one?
