Where would the possible relay be located and what type of relay does it use. There was also a washer on the rear window and the switch seems to have two still positions and one third position, which only stays on when you push the button, when you release it it comes back to position two. I guess the third one is for washer, second is the wiper on and first is off of course.
It's a multipin switch, has more pins than the one in technical resources section, but it looks the same and comes next to foglight switch.
So where would I find the relay if there is one or can I use some general wiper relay.
What's funny is that the 340GL from which I took the wiper was an UK model with RHD and had GB sticker on the boot lid. Long way from home.
There was also a clean looking (for a junkyard car that is) white 3dr 360 GLT, I tried to take out the fogs but it was kinda tricky because the car didn't have wheels and the phillips screws with which the fogs were attatched, were badly rusted so it would've required some cutting or drilling of the screws... Too bad because those looked super clean, maybe I'll take a cordless drill with me and take those fogs also at the next week.
