hi i have just swapped a dash assy from my 88 1.4gl into a 85 1.4dl and the rev counter is not working
any body got a wiring
diagram so i can check this out
cheers martin
rev counter
- volvodspec
Re: rev counter
under the bonnet, find your renix ignition unit. there should be 3 wires in the far right plug, one of these is the rev-counter signal (i believe the outer one, but not sure). if the factory did not pre-wire it, one of these wires will stop at aprox 15 cm of the plug.
Re: rev counter
hi has anybody got a wiring diagram for a 85dl 1.4 rev counter
cheers martin
cheers martin
- trabitom99
Re: rev counter
Have you tried the Green Book section?
http://www.volvo300mania.com/forum-uk/v ... =36&t=7261
Re: rev counter
found the problem...its not wired up from the renix to the fuse box....but it is from the fuse box to the dash
