Rear wheel bearing
Rear wheel bearing
My car is '84 and has old style bearing, 52.116(Scantech number)(3294713 original)
But it is not possible to find it anymore...
Does anybody knows, if it is possible to change it with new style 52.117?(3411886 original)
'84 360
- trabitom99
Re: Rear wheel bearing
Their still available from ScanTech as far as I can tell. Their German supplier lists them, as does this supplier in the UK ...
http://www.scantechparts.co.uk/acatalog ... 0_360.html
well..
52.115 is for 340 with b14 engine
52.117 is for 3xx after '86
both of them are available here, not from Scan only, but from SKF, NK, etc..
but I need 52.116-it is not even listed there..
or confirmation that it can be easily changed to 52.117
'84 360
- trabitom99
Ah sorry, I didn't know there was a difference in <85 340 and 360 rear bearings.
If I type the Volvo part no (3294713) in my Skandix CD (they buy stuff from Scantech mostly) I get:
Radlagersatz hinten 1000986
Volvo 300 (360) 3294713
Achsaufhängung 2 Stk.
Volvo 360 nur Baujahr 85
bis Fahrgestellnummer 120999
45,91 EUR
Might be worth contacting them:
http://www.skandix.com/
45,91 EUR
It could be nice site, but it doesn't offer any parts for 3xx:))
in their catalog you can select 2xx, 4xx, but not 3xx-it is disabled.
Original bearing is to expensive:(
'84 360
Early 300 rw bearings have separate oil seals as well as the bearing, the later style had the seals in the bearing
this
and
rather than
in lates. as to compatibility, no idea, but the early ones should be easy enough to get hold of from a normal bearing shop, a good make such as Timkin or SKF would be fine if you can measure the old one.
this
and
rather than
- trabitom99
Yes, they don't list the 300 parts on their website, only on their CD. They sent me one free within a day or so of requesting it. Their website looks a bit primitive, but they're one of the major aftermarket Volvo parts dealers in Germany, the other one is "Wagner und Günther" but they sell nothing for the 300 AFAIK.nekto wrote:It could be nice site, but it doesn't offer any parts for 3xx:))
Let me clarify..
340 with B14 has 2 bearings and a seal ring:
360 and 340 with B19 before '86 has a single bearing:
and after '86 bearing from 4xx is used and it is going with a hub:
Firts type is not interesting for me.
'84 360
Are you sure? If so I'm about to go and buy the wrong one! I thought the middle one was post 86, never seen reference to the last type! I'll have to actually look at the axle now
Yes, I'm sure. This is according to my local Scantech dealer
Also it is mentioned it Scantech catalog.
'84 360
I *think* scantech have there pictures mixed up. Vadis quotes part number 3411886 for my late 89 340, and a search for that part number shows me the same picture you show here
http://dead.hub.lv/Volvo&SAAB%20Detalu% ... ing-1.html
from a scantech catalog, but the picture I'm expecting from this scantech catalogue
http://www.scribd.com/doc/2889375/suspe ... ring-volvo
and also lists it for 4xx.
This separate company also shows the double width sealled bearing for all late cars with the same part number in reference.
http://www.propartssweden.com/filer/Pro ... _volvo.pdf
The picture in green books, Haynes, Russek and Vadis show the double width without flange too, so I'd be most likely to stick with that.
However, as you have an 84, I'd also be pretty sure that you must have the 2 separate bearings and oil seal currently, so really don't know if you can switch to the double width one
Vadis if you select an 85 car (the oldest it has) amusing shows the diagram says "86- only"
I'm sure that I have only one wide bearing:)
Two narrow are for B14 engine only.
And last one is for car with chassis number CH.121000-
Vadis is a strange thing regarding 3xx...
Diagram is for 86-, but shows -86 wide bearing...
Also if you look at rear bearing of 440, it will be wide with flange. So scribd is not correct..
I think the only way to solve the problem-look at what you have. May be I'll lucky to see last type bearing tomorrow
'84 360
I think you are right! Let us know, I'll do the same when I do mine.nekto wrote:I think the only way to solve the problem-look at what you have. May be I'll lucky to see last type bearing tomorrow
Now I' completely confused..
I saw 52.117 from Scan, and it looks exactly like this:
No hub, just bearing and a nut.
So I don't understand, what number shall I buy..
'84 360
That is what everything apart from the info you've shown has said is on post 86 cars mate! All my info shows 340's and 360's pre 86 being double bearing... have you had it apart yet? That really will be the only test for certain.
