Kelvin- Brisbane
fitting a new dashboard!!!!!
kelvingenders
Hi, just wondering if this hard to do in an 1986 360 GLT. I live in Australia and the one in the car has cracked due to the heat experienced in Queensland. I need to remove the original one and wanted to know people thoughts....will it go back together again? will there be instrument or switch rattle? which is the hardest part?
Kelvin- Brisbane
Kelvin- Brisbane
- volvodspec
Re: fitting a new dashboard!!!!!
its easy!
- remove steering wheel
- remove the 2 black panels under each side of the dash
- remove the interior trim that is against the tunnel (just pulls off)
- remove the clockset (undo speedo + 2x connector and if you have it, the hose for the eco gauge) with the 2 screws on the top side of the thing
- disconnect the light switches, for rear window heater/foglight it is the easyest to pull away 1 of the lighting bulbs on them so you know where to put them back
- remove the lightswitch panel, 2 screws on eash side
- remove the radio/radio panel, undo the 2 screws that hold the dash (you can see where the clips are if you look at it from the side)
- undo the 2 large screws (10mm wrench) under the sigaret lighter/ashtray
- undo the 4 large screws, 2 on each outer side of the dash
- remove the glovebox (8 screws and lightbulb) and cut the 2 zipties holding the loom
and then you should be ok to pull the thing out of there
