six dial dash
six dial dash
Post by redline » 24 May 2006 01:08 pm
econ , ambient temp, speedo , revs , fuel, water £30.00 exchange for standard dash , will include ambient temp sender and econ pipe and t piece
sorry picture taken before econ gauge fitted
be quick as car may go next week
dalahare
Post by dalahare » 24 May 2006 05:05 pm
fark me it's cold where you live! :lol:
Bilbo
Post by Bilbo » 24 May 2006 10:05 pm
:mrgreen:
shimon340
Post by shimon340 » 24 May 2006 11:36 pm
good one! :)
Enjoy your 300s
Re: six dial dash
Post by redline » 25 May 2006 07:58 am
redline wrote: Image
and there was little old me expecting some comment from Foggy like
"why is the petrol gauge needle pointing straight up, is there something wrong with it coz I have never seen mine like that "
for those poor ( and I dont mean financially ) people who do not have an ambient temp gauge ( £30.00 exchange for standard dash in case you had forgotten ) the gauge go's to -40 when the ignition is off .
just as the econ gauge( which is also included in this bargain package) rests in the red when the engine is not running
d3k4y0
Post by d3k4y0 » 25 May 2006 08:01 am
if you can't sell it as a job lot mick, I'll have the temp guage and sender off you, it's all I'm missing
Post by redline » 25 May 2006 08:14 am
I know it means you coming down to Mk dave , but you would be better off doing the swap and then selling on the econ gauge and rev counter , you would probably recover your expenses so it would be worth the trip especially if you want the steering wheel as well.
d3k4y0
Post by d3k4y0 » 25 May 2006 08:32 am
put simply, I can't afford it mick.
I can stretch to £45 because I've got a bit tied up in paypal, but i can't afford £70 (plus petrol), plus I'm far too busy with my last couple of weeks at uni (ever) to be trying to sell stuff on to recoup losses, money is incredibly tight
garethreece
Post by garethreece » 25 May 2006 11:36 am
Slightly off subject her but how does the ecometer work. My instruction tells me one thing but my dials slightly different so i cant tell what it means :?
B980EAV '85 340 GL
SMO58Y '83 360 GLS
VK06FKP '06 Suzuki Swift 1.5 5dr
N62NTG '96 Ford Mondeo 1.8TD
And only 2 of them are on the road :(
Post by Chris_C » 25 May 2006 01:58 pm
It takes the inlet manifold vacuum. This is my understanding that follows...
All the pistons should generate a vacuum, as they go on the correct downstroke, sucking *stuff* (fuel/air mix) into the piston. The manifold is just connecting the pistons to the carb, if the carb butterflies are wide open, air rushing into the manifold to balance air pressure, this is econ in the red zone. When the butterfly is shut, air can't rush through, vacuum is held in the manifold (to an extent) and is white zone.
The reason no vacuum is the red part, is fuel is only 'pulled' into a carb engine, not pushed, it works like an airbrush, so the more air going through the carb, the more fuel is used.
(The main reason I just went that detailed, is as I have an idea for my engine, and want someone to correct me if I have the wrong end of the stick ;))
Carl
Post by Carl » 25 May 2006 05:12 pm
I think that's basically right Chris.
Same sort of thing on the EFI, except the fuel isnt pulled in from the air rushing through, the air flow sensor senses more air and injects more fuel accordingly. So more air = more fuel. And more vacuum = less air = less fuel = better economy (ie the white zone).
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
Post by redline » 25 May 2006 05:39 pm
yeah o.k. you to , take it to the technical part of the forum , I'm trying to sell abloody dashboard here !!!!! lol
Post by Chris_C » 25 May 2006 06:53 pm
Sorry Mick!!! Hang on, I'll try and make thingsright again...:
"Step right up eeeeverybody, yes, that includes you Madam.
Today we have for you a super-iffic, info-riffic, 6 o riffic dial-tastic of a bargin. Come forth and see the wonders that will astound astonish and amaze, whilst telling you you are needing fuel, yes, thats right, the yellow fuel warning light WORKS!!!
Grab yours today at the bonza bargin price of just £30 and your old dash cluster, but hurry, I only have a limited supply..."
Post by foggyjames » 26 May 2006 02:00 am
Vacuum is created when the engine tries to suck air out from an enclosed space (the inlet tract with the throttle(s) closed).
The fun starts when you look at the new BMW engine which doesn't make vacuum in the conventional sense - it limits engine output by reducing valve lift down to almost nothing. Very damn clever.
I'm getting tempted to get a temp gauge for Nessy.
Carl
Post by Carl » 26 May 2006 09:48 am
It gets even more interesting if you tried to hook one up to a diesel engine!!!
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
