Kelvin
Track rod ends - removal of nut
kelvingenders
Any ideas which way the nut should be turned (anti or clock wise) to release this nut so i can remove the track rod end?
Kelvin
Kelvin
Re: Track rod ends - removal of nut
The nut which holds the TRE to the steering arm or the nut that locks the TRE onto the track rod?
Doesn't really matter as they are not handed. Anticlockwise, but it does of course depend which way you are looking at it...
kelvingenders
The nut that locks the TRE
I refer you to the answer I gave earlier...kelvingenders wrote:The nut that locks the TRE
Looking from the outer end in towards the car that would be winding it clockwise.macplaxton wrote:Doesn't really matter as they are not handed. Anticlockwise, but it does of course depend which way you are looking at it...
Normal anticlockwise.
If the stud is turning aswell, jack the car with the jack under the track rod end until it stops turning.
