You can calculate that, standard camber was something like -0.2 degrees, if you aim for -3.5 degrees how much bottom of tire need to move? Then just figuring out how much to add material, it is not much, few mm.
You can even take center point of wheel check distance to arm and calculate how much that few degrees will be to get directly correct answer.
Volvo 360 Cup Thread (Motorsport coolness)
Re: Volvo 360 Cup Thread (Motorsport coolness)
The pictures on this tread are from before 2008.
This year is the tenth anniversary of the Dutch Volvo 360 Cup and there’s a new website where you can see the cars from all the Participants in 2010 (Including myself; car 407)
http://www.Volvo360cup.nl
thanks for the link Mike, its much appreciated.
And good luck for the season.
edit* for direct vid link
360 cup vids
360 cup vids
I proper love that someone still races these cars, hopefully it will be televised
Thx from the linkMike7 wrote:The pictures on this tread are from before 2008.
May the racing goddess ride with you to victory
Thanks for the replies!
The best thing of racing in a Volvo 360 is the face of some guys in there BMW E30 325I (170 HP) when we drive past them
For next year there are some plans to put a 2.3 engine in the cars to make it a bit faster.. What do you think about that?
I don't know about changing engine, currently as I understand V360Cup has been interesting because cars are very much the same, it has been very restricted what can be done so it is almost same which car driver takes result would be more or less the same, which I think is great, but if engines are being changed, can same still apply or would there possible be someone with more power than other?
It would change nature of motorsport, but maybe it could work if equality is kept the same.
At least 2.3 would help a bit of that 2nd to 3rd shifting, as rev drop is quite big and more torque of 2.3 might give big helping hand there, also wet races might become lot more interesting, when torque is really giving issues with corner acceleration
With 2.0 it is still not an issue, but when I had bit tuned 2.0 it required some throttle control on track when it was wet, power was bit higher than 2.3 and torque around the same, however I had standard suspension and 14" not so good tyres, with your setup things are probably bit different, it turns better and inner rear tire lifting is less of issue if I read V360Cup car specs correctly.
So I'm two minds about it, it will make more interesting, but there is risk of escaping costs and wins to those that have lot of money, unless great caution with rules is being made.
Btw, I did try to outrun 325i once with stock motor and 200 000km driven suspension, it was impossible with my abilities, I felt that I would need lot more grip, also brakes faded out so I was left behind running wide of corners while brakes smoking, servicing of brakes would of helped at least a bit there, my lame excuses
