fornt camber?
samueljon
fornt camber?
Post by samueljon »
been playing about in the car, had a good look over it at the weekend (still havnt done the reverse light as yet)
just wondering if it is pos to run front camber on the 340's and whats involved in doing so
Sam
samueljon
Re: fornt camber?
Post by samueljon »
anyone have an idea?
OppositeLock
Re: fornt camber?
Post by OppositeLock »
If you have access to a machine shop, it doesnt take too much to whip up some camber tops.
samueljon
Re: fornt camber?
Post by samueljon »
i used to but have finnished college now :(
only way to do it is custom then??
L14MNP
Re: fornt camber?
Post by L14MNP »
I haven't paid much attention to the way you would adapt a 300 fror front camber (yet) but can you not just slot the holes in the strut tops?
STREETO WITHDRAWL
INTO BURNOUTSsince1982
samueljon
Re: fornt camber?
Post by samueljon »
how would you do that with out weaking the strut tops??
also is there anywhere that do strut braces for the 340 or again a custom one would have to be made?
mat_91
Re: fornt camber?
Post by mat_91 »
custom strut tops would be the way to go but one question are you lowering it as you gain enough camber mine is currently running just over 1.3 degrees with a 75mm drop other than if your not lowering i wouldn't bother if you are lowering it id look at returning standard geometry to the suspension first
Re: fornt camber?
Post by 340GLT »
Have a look in my build thread mine runs camber plates on the front.
samueljon
Re: fornt camber?
Post by samueljon »
ye its running slight camber but didnt think it was great, i suppose with a proper set up it will feel alot harder/ feel more
