my mates granda has a 960 2.3 turbo which im gonna try gettin off him for some winter fun, my 1st question is how exactly can i figure out if its HPT or LPT?? is the engine codes different or are they both b230ft with different turbo codes jus?? what are those codes??
secondly, depending on which turbo it is, how could i up the power?? ecu chip for feulling an up the boost?? will it take a boost increase ok?? can the boost be done via a bleed valve??
thirdly, cooling...will they overheat easily after a power increase?? can the intercooler be changed easily enough for a slightly larger 1, not too large as to decrease the performance tho...
forth, diff... how or where do i look to see if its already equipped with the sacred locker?? can get 1 anyway but would be nice if it came with 1 already...can they take abuse?? same question for gearbox an clutch.. can they take the power increase and some abuse with ease or are they a soft spot??
anythin else related please post...thanks fellas
