HELP........
HELP........
like a fool i let my brother put a cd in my car.but for some reason my rev,fuel,and all the dash has stoped working but all fuses are OK anyone no whats wrong
Re: HELP........
Checked the block connectors still in at the back?
Can't see how putting a CD in the stereo would cause this though.
Oh we have a tech section aswell
Re: HELP........
Hmmm. Do you get any lights at the top? It's likely that if none of them work then the circuit has broken. As they all run through one earth I'd put my money on that.
Re: HELP........
he pissed about with a green wire and used it for a live to the cd..
- volvodspec
Re: HELP........
the green wire is a 15+ or "ignition on" wire,
you are ment to hook the radio up parralel to the original plug. he used the green wire as a feed for the radio; this means the cluster doesn't get current. solution is to keep the green wires attached (actually all the wires that are there) and then connect the radio to them.
has he cut the original connector/plug off? there are original plug & play looms from the volvo connector to ISO standard connectors you know, they don't cost a thing
Re: HELP........
Sorry my misunderstanding, he's put a CD headunit in the car.
Not just a Cd into the headunit like it sounds like it's worded
Re: HELP........
yes he cut the plug ..i think he touch something and shorted it. but he says he has not....YIPPPPPYYYYYYY SORTED THANKS GUYS
Re: HELP........
z0mg he cut the plug on the 25K mile wiring loom?!
What Anjo is saying makes sense. Whatever happened to testing things first?
I gotta agree too, CD sounds like you mean the disc and not the HU, but you can just about understand it.
Pull it out and put back the feed to the cluster then do it/get your brother to do it properly. I thought you were a mechanic?? I know technically that's auto electrican territory, but it's also car modifying 101!
Hope you get sorted.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
Re: HELP........
YES sorted it. thanks again guys...i can do it myself but i was working so he took it to himself to put it in
...i will do it myself this time.....
Re: HELP........
yep....
