B14 wants to over heat
kaarel
Post by kaarel »
Hei
Due to the fackt that out side temperatures are rising and now daily temp. is plus 12, my b14 (cvt) wants to boil.
Problem is then when car idle´s at neutral or like yesterday road was very crap so had to drive about 800m with 15km/h.
Engine temp. went high the temperature red light didn´t flash yet but were quite close.When got normal speed up then the engine cooled down and every thing was fine.
Don´t think that is normal?
belt is old and quite wear-but don´t slip,have a new one but haven´t managed to fit it.
coolant is changed and radiator is fine to,don´t think is stuck too.
water pump doesn´t make sound,so should be ok ?
termostat is working.
Any ides?
K.
Vermilion
Re: B14 wants to over heat
Post by Vermilion »
Does the radiator fan work? It should go on when the coolant reaches a certain temperature
Volvo 340 L 1983
kaarel
Post by kaarel »
Yes fan is working.
Will do the radiator flush, may by it is stuck.
Vermilion
Post by Vermilion »
While you're at it get a new thermostat, maybe it doesn't work properly anymore
Volvo 340 L 1983
morgan105
Post by morgan105 »
What sort of condition is the radiator in?
If there are a load of missing mesh fins in the rad then it would be better to get it replaced.
Is your expansion tank cap the correct pressure rating?
CBA
Post by CBA »
Fan works, thermostat works, car only cools down when driving at speedz - water pump is worn out sm49
