making lowering blocks
minimaniacwhyard
Post by minimaniacwhyard »
im new here just bought a 340 (its awesome) but cant seem to find any three inch lowering blocks. im thinking about making them out of steel myself as they look fairly simple anyone ever done anything like this?
Re: making lowering blocks
Yep, last week:
2 inch box section with thick steel on the ends, top drilled and tapped for a locating bolt to sit in the hole on the top of the leaf.
minimaniacwhyard
just made mine actually went out and bought some 60*60 box section. ill put the locating studs in mine tomorrow. all measured up will get some pics up when its all done. thanks for the advice. :D
valman
Post by valman »
i just got a meter of 4"x2" steel box with 3mm walls and its done 6 volvos now and i still have a few pairs of blocks left. mine werent as good as speedys though, i just simply cut th desired length and popped it in between the axle :D
minimaniacwhyard
my lowering blocks are now made and fitted after a lot of trouble getting the driveshaft out the offside. flamin allen key bolts rounded off. all repaired though. ill get some pics up once the fronts done now. not long till thats all on the road. :340: cant wait!!!
