wheel bearing?
tim-andre
wheel bearing?
Post by tim-andre »
does the rear wheel bearing from a 85 fit a 84? same brakedrums, and im guessing everything else there is the same too, but when i searched after the rear bearing on work is says it goes to 85 models and up.. so just want to ask before i buy the wrong one
War isnt about who is right, but who is left
Re: wheel bearing?
Post by Ride_on »
Search harder, and/or provide better information. What car are you talking about?
tim-andre
Re: wheel bearing?
Post by tim-andre »
Ride_on wrote:Search harder, and/or provide better information. What car are you talking about?
360, got an 84 model now, and the bearings we get on work are for 85 and up, ordered one and it will get here by tomorrow, so will find out then
the bearing on my car is fucked, so i took the chance, since it doesnt cost me much
volvomania
Re: wheel bearing?
Post by volvomania »
It all depends on the chassisnumber:
per side
340 up to FC120999 is 2x 3105765
360 up to FC120999 is 1x 3294713
340 & 360 after GC121000 is 1x 3411886
I know some used to sell a uni set for 340 and 360 up to FC120999.
tim-andre
Re: wheel bearing?
Post by tim-andre »
my chassisnumber is XLB343213EC848901
it does not say on the bearing ive ordered what chassisnumber it goes to, just that it goes to 85 modells and up
Re: wheel bearing?
Post by Ride_on »
Theoretically then you have the early type, which is a multi-piece. Sounds like you have bought the later single piece sealed job.
Not sure about the earlier one, but the later one is a one way job, once you start you have to replace, the old part is destroyed in the disassembly.
This thread has alot of info;
http://www.volvo300mania.com/forum-uk/v ... +rear+ride
This thread says something similar about the chassis no, but doesn't include the letters, do they count?
Does you car have the large lump on wheel flange? If so I think it is the later bearing. If it is the later one I can guide you to change it, I even have spare circlips.
tim-andre
Re: wheel bearing?
Post by tim-andre »
i will mesure the bearing on the old one, found 2 different when i searched for wheel bearings on my other 360 registration number, and both says outer and inner diameter of the bearings
what i also found out is that the 86-87 uses a different bearing than what i ordered, so i hope i got the right one :lol:
Re: wheel bearing?
Post by Ride_on »
Yes the Haynes info says 86-on is all single piece seal type, but I wasn't sure about the accuracy of that as one of my cars contradicted it, but it may have had a new axle before I got it.
Did you look at your hub? The later type have wheel centring lump about 1cm long the earlier ones only 2mm or so.
volvomania
Re: wheel bearing?
You should indeed have the early version.
tim-andre
Re: wheel bearing?
Post by tim-andre »
new bearing got two pieces when you look in the midle, is this different from the other?
found out that the bearing for my 87 360 has 2 mm bigger diameter than what ive ordered, will find out soon enough if it does not fit or not, changig tyres and bearing tomorrow
thanks for all the replies!
