Volvo 360 From New Zealand
durty
Post by durty »
These pics cover the last 5 years
When I first got it
Then a Few Pics of its changes over the years
And some pics as it sits today
Logan360
Re: Volvo 360 From New Zealand
Post by Logan360 »
Ha! i knew it would only be a matter of time! welcome, you will find all the answers you need to any questions floating around somewhere.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
malcolm nz
Post by malcolm nz »
hi there how have you gone about lowering it? what springs ect? is it legal height? where abouts in new Zealand are you?
durty
Post by durty »
Hi there.
It has 2 inch blocks in the rear with shocks from the front of a diesel land rover. Very stiff
Has a set of progressive king springs in the front but unsure what they are out of. Found them in a pile at a wreckers. Has standard shocks but need to replace them with some stiffer ones.
Front is a bit uncaptive but will be sweet when I put some new shocks In and get them shortened.
Is illegal height with the red wheels on it. Sits at about 75mm to 80 mm off the ground.
For wofs I just put on some 14s with taller tyres so it scrapes in over 100 mm (just)
durty
Post by durty »
Also I am in Wellington.
Am planning to build some front coil overs for it to go a bit lower still and will get it certed for the lower height
Logan360
Post by Logan360 »
Hit up dai. he's got front lowering springs.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
durty
Post by durty »
By the time you add in shipping etc it would be almost as cheap to get custom wound springs made here
I also read that the really low version of dais aren't captive with standard shocks somewhere?
Logan360
Post by Logan360 »
Yea you read right but his superlows aren't legal here anyway i think.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Post by classicswede »
You need to use the shortened adjustable dampers with the lowering springs to keep them captive.
The other option is to have the std ones machined down in length, but for the hassle you might as well make a better job of it and use the adjustables. You guys should look into a group buy to save on shipping.
Logan360
Post by Logan360 »
Were all broke asses lol plus mine sits quite nice at the front. lower than standard.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
skd360
Post by skd360 »
Hey I'm from Australia and just purchased a 360 got it's already got re set leafs is ther an exact model of the diesel land rover that u get the shocks from and are they front shocks or rear ones u get ??
