1.7 turbo
1.7 turbo
Hi guys I'm doing the swap from 1.7 to turbo, and I have a question about ignition system and the flywheel, could you help me , I dont have flywheel or ignition coil from the turbo unit, is it possible if I put the 1.7 engines flywheel which has injection system, and put the stock ignition coil, would it work with the turbo ecu? Thank you for answers, because its hard to get the turbo parts for me
Re: 1.7 turbo
You need to the turbo flywheel.
Is the engine from an automatic?
Re: 1.7 turbo
Engine is manual, and also I need ignition coil from turbo unit yes?
Re: 1.7 turbo
yes you will and all the wiring to go with it
