Black Metallic, Limited Edition Volvo 360 GLT, 4 door saloon.
First registered 24.03.1987, D776 WFW. 2 owners from new, with Volvo folder, owners manual, old MOT's and service records to 1997. Both original keys present.
The speedo is showing 84,000 miles, however the speedo was replaced due to a fault and the actual mileage covered is 114,600, there is an invoice to substantiate this from H.P. Firman, dated 07.03.1994
The car has been standing outside for sometime now, but the engine was last running in 2002. Just before being laid up, the car had a new timing belt and water pump, exhaust and service. When last used in 1997 the car ran extremely well, everything was tight and sound. The only fault I was aware of then was a whine, which was coming from the nearside rear wheel bearing.
The car will require some minor work to re-commission. There is some corrosion on the n/s front wheel arch area, a minor dent in the n/s front door, above the door handle since standing and minor corrosion on the offside rear wheel arch on the return edge flange. The interior is very clean and undamaged, the car in general is very original and totally complete, with spare wheel, jack and brace.
Well worth saving by a 360 enthusiast.
I'm not looking for a fortune, I'd like it to go to a good home, so please make me an offer.
Please contact me, Pete, via my email or send me a PM and I'll either answer any questions, or put you in direct contact with my Dad via phone. Thanks.
I believe it relates to this anniversary model.
The actual car, not the best of pictures, can get take some more on request. The reversing lenses are with the car, removed before they fell out, so they didn't get lost, nicked or broken.
