H reg 360??
H reg 360??
This can't be right but...
http://atsearch.autotrader.co.uk/WWW/ca ... ull=SEARCH
The manufacturer date is also correct though? It's surely a 360 because it has colour coded bumpers.. Strange...
MJ
Post by MJ »
They could have swapped bumpers ;)
Could've but doubt it, besides.. it's under 360 in the search.. so it adds up. The only thing that doesn't add up is the date.
petefarrell360
Post by petefarrell360 »
Hmmm, 1990 I could believe, just, if it had sat at a dealers for sometime unregistered, but 1991 on a H, I dunno. Only real test would be to ask what the engine size is on the logbook. Interesting find!
Post by 340GLT »
Given that it has PAS aswell i would say it is a 60. As for the reg its not an impossibility the last ones of the 340's are on a J plate. And it is possible to get 400's which were stopped in production in 1996 on an R plate, and 240's as late as L i believe!!!
Cheers Adam
Post by 340GLT »
I forgot to add it all depends on when the car was actually registered. As my car is an F reg and on the V5 is registered in 1988, however the car is an 89 model as it has a rear high level brake light and came with an 89 owners manual!!!!
Cheers Adam
Post by redline »
the car is in Larkfield in Kent
Post by foggyjames »
Well as far as model years go, they normally run a year ahead - ie: mine is a late 1988 registered (so probably built months earlier) 89MY car.
That car probably sat around unsold for a year - so watch for rust. Pretty pimp having an H reg 360...probably about the only one in the country. Probably a B200K too...I'd buy it.
Post by 340GLT »
On a similar Topic does anyone know of any J reg 340's as there is one in Ludlow!!!!
Cheers Adam
J reg 340s aren't so rare....ie: you do see them from time to time. I took my B14 PAS kit from one, for example. An H reg 360 on the other hand is a bit :shock:
petefarrell360
Yeah, there's a J reg 340 local to me on and off, seems to live away a lot of the time, but returns around the holidays! A H reg 360 is indeed something rare, getting towards hens teeth and the rocking horse crap. I've got a G plated 360, which is also pretty rare. And all the G plated 360's I know of were only just G, as in they made the new plate cut off by a day, which makes a H very rare. As suspected, it propbably sat around before being sold.
Kar's a Late '91, 6 weeks off a J, and there is a J on my road on the island, and I believe Shimon has a J too. Beast was a G plated '60GLT, I'm almost tempted to go and look at this one... That wasn't in the plan
Go for it ;) It's exceedingly cheap!
Just had another proposition in the last 20mins, might still go and check that one out
