Shout now if you would like a white headlining for a saloon, with a sunroof trim panel, as I have a pretty clean one that I could remove before the car leaves, but I wouldn't go to the hassle unless someone wants it!
Also I have a pretty clean carpet for a 4 door, which I can't see why it won't fit a 5 door either, as the internal floor should be the same. It's the rougher grey with flecks and rather wiry carpet, as opposed to the shorter ligher grey carpet! Once again, I won't be removing it if no one wants it, so call dibs now. As everything else if out, it will come out as it went in at the factory, with both centre console trim panels.
Headlining and Carpet
- petefarrell360
Dibs for the headlining if it's not too much of a pain for you
- petefarrell360
