How about a section about special tools in the resource part
Chesh740R
Post by Chesh740R »
As the title says, where you have the blue leaflet section and green books etc etc, why not one with the special tool numbers and there uses.
I've been cataloging my Volvo Special Tools today.
I would assume a lot of the engine tools are on my 200/700 boards for the redblock engines, and possible the 400 boards if its renault related.
Here's the list i've got from my 300 blue peg board, if you know what the tool does please update the list, I don't have my green books for the 300 series anymore so i cant trawl through them to find out what they do like i'm slowly having to do with the others i have.
Peg Board Tool No Have i got it What it does
300 1 5801 no
300 1 9995803 yes x2
300 1 9995849 yes
300 1 9995807 yes
300 1 9995953 yes
300 1 9995920 yes
300 1 9995908 yes
300 1 9995902 yes
300 1 9995865 yes
300 1 9995868 yes
300 1 9995862 yes
300 1 9995911 yes
300 1 5869 no
300 1 1158602 no
300 1 9995947 yes
300 1 9995919 yes
300 1 5937 no Door Hinge Remover
300 1 5948 yes
300 1 9992412 yes
300 1 5893 no
300 1 9995866 yes
300 1 5938 no
Regards
Chesh
Awesome, good idea Chesh, I can't do it, but I from what I remember the hack I stuck onto the forum to allow the green book etc sections will take it.
What are your plans for the tools? Will you loan them to people?
pettaw
Post by pettaw »
IIRC he's sold them all to Foggy.
Chesh740R
Post by Chesh740R »
pettaw wrote:IIRC he's sold them all to Foggy.
No I sold him my 300 series green books,
He has expressed an interest in the tools so he will get first option should i decide to sell, and he has mentioned he'd lend them out.
I'd be up for lending them out if need be, but to be honest in all my years working on cars, i've never ever had to resort to using a special tool, allways managed to get round it someway or other.
Maybe it was the cost of the tools that put me off, or the need to finish the job that day.
Allthough i think some of the usefull tools are what look like presses or pullers custom made to make jobs very easy.
If i'd had the time i would photographed each tool, but with over 300tools it was a task enough just listing them out.
IvanAE86
Post by IvanAE86 »
I am blessed with the luxury of being allowed to work at a volvo dealership. They have loads of racs all filled with special tools.. in all the days I've worked there, the only things I ever used from the special tool racks for bits that seemed to fit the bill to use as presses or punches.. nothing a few sockets couldnt have handled just as well. I daresay you dont need 95% of those special tools to get the job done.
Yeah, agreed, the only thing I've bothered with in the 6 years I've had 300's is the 1.7 cam tool (really must actually use it as opposed to leaving it on the shelf...)
When I get a bit of time spare, I'll have a look in the Russek stuff, as that has the special tool numbers listed. Wouldn't be for a week or so though I'm afraid :( Thanks for putting those numbers up though mate, I agree, the pullers etc would save a lot of effort.
Post by foggyjames »
Your post has made me have a brainwave. I tried to get hold of the hinge pin tool, but no luck. They sent me the wrong part. However, it's pretty obvious now that to convert the (four digit) tool numbers listed in the green books to parts you can actually order, you just add "999" on the start.
They got me 9995037 (typo?!)......time to try ordering 9995937!
Hahaha, yeah, 999 is the special tool code. Not sure if Andy told me that, or I read it in Russek, but my parts blokey knew it, and got me the tool with me only telling him the four figure ref.
Surely your dealer must have known?!
In a word...No. I'll take GREAT pleasure in telling them tomorrow...
BTW...how soon can you send me my parcel ;)
Sorry dude, I've been super lame with the secretarial side of things lately (as a couple of peeps on here will know, sorry guys :oops: ) Yours is the last to be done mate, everything else has been sorted, so I'll get onto it pronto.
Now to suss out hows best to send the stuff!
1stRaven
Post by 1stRaven »
put it this way, our parts dept in lincoln volvo seem to be very special. Like James, I have given them parts numbers, only to find the wrong part to turn up. Double check and they either mix the numbers around or on really special moments, order something where the part number is completely different.
BTW, I think Nessy knows it has something on the way for it - it cut out on the way to work this morning. :roll:
[center]
[QUOTE=foggyjames]...Ryan's car is pretty much spot-on....[/QUOTE]
[/center]
Lol, she'll have a new carb and spare renix for the beginning of next week ;)
I might check the pump and hoses (although they *look* good) too...but fingers crossed the carb will sort it.
Result: Tool costs £50. I might try another dealer tomorrow to see if they're fleecing me...otherwise....anyone want to hire one?
I have access to one at the moment, but I see this being a very useful item!
Info so far (this is including others, not just Chesh's) These are from Russek, which will not mention a special tool unless there really isn't another way that doesn't count as a bodge, so not all will be here.
5989 - B172k Cam locking thingy for valve clearance adjustment
5994 - B172k Rear crank seal fitting mandrel
5973 - M47R II Head for puller used to remove 5th speed casing
5305 - M47R II Lump for pulling 5th gearwheel out
5262 - M47R II Pulling stick for 5305
5986 - M47R II Undoing device for 5th gearewheel dismantling from syncro hub
5261 - M47R II Front bearing puller
2985 - M47R II Lockplate to prevent damage to syncro ring, also used with 5096 to adjust preload
5058 - M47R II Used in conjunction with 5148 and 5147 Mainshaft bearing extractor
5148 - M47R II Used in conjunction with 5058 and 5147 Mainshaft bearing extractor
5147 - M47R II Used in conjunction with 5148 and 5058 Mainshaft bearing extractor
5306 - M47R II Drift to fit 5th speed gearwheel and spacer ring with 5307
5307 - M47R II Drift to fit 5th speed gearwheel and spacer ring with 5306
5096 - M47R II Used with 2985 to set preload adjustment for rear countershaft bearing
5893 - Rear wheel inner drive flange puller
5866 - Front suspension to wishbone balljoint undoer
Right, thats the 1.7 Russek book done, might do another later... maybe!
