ignition problems
sps
ignition problems
Post by sps »
hi
i have just put a 1.8 16v renault 19 engine in my old 1.4 340. It running bike carbs and no ecu.
i have used the old 1.4 condensor and coil but i do not know what else i need. I know that some how there needs to be a sensor to say when to fire but where is this - i know there is a sensor on the flywheel - is this it? How do i link this up to what i have at present.
Any help would be great - its so frustrating when its this close and its holding me back
THanks
S
Josh_Cohen
hi
Post by Josh_Cohen »
your best bet is to talk to Adam he is a god lol he has done the conversion so he should be able to answer cheers josh
New User Long Time Lover Of Volvo 300's
Post by classicswede »
If you are running cars them you just use the original renix unit and crank sensor. The senor is held on with two bolts to the bellhousing. The renault flywheel will work fine with it
If I remember rightly sps's car is an 82 340... which has a more traditional ignition setup rather than renix
sps
Post by sps »
yeah its the old 1.4 1982/3 model - i do have the sensor on the bellhousing though no idea how to link it up to the existing ignition system to make it all work?? do i need more things off a 1.7?
bennett
Post by bennett »
you need the flywheel sensor plug it in to the coil pack and in to the dizzy cap
bennett
Post by bennett »
to link it cut the old conector off the 1.4 loom there is only 2 wires
