foggyjames wrote:It would be interesting to get an update, when Peter knows what failed.
True, thanks for the reminder. Im not so often here at V3M.
300 Power takes all the time
Here is the "weak" link of Peters driveline:
Broken transaxle:
http://www.300power.com/forum/index.php ... 1797;image
Nice surface at the "cut":
http://www.300power.com/forum/index.php ... 1799;image
If you look carefully you can se that the splines are twisted:
http://www.300power.com/forum/index.php ... 1801;image
And the cause to this is:
344 hp at 5026 rpm @ 495 nm at 4895 rpm! (Without NOS)
453 hp at 4851 rpm @ 686 nm at 4573 rpm! (Whith 100hk NOS)
All measured on the wheels and with 1.2 bar of boost!
The recipe:
Engine block: b230fk with oilcooled pistons.
Pistons: b230fk shopped 3mm because of the marine
crankshaft.
Crankshaft: Marine crankshaft -86 mm stroke = 2½ litre.
Pistonstakes: Big b230 stakes
Flywheel: Lightened original, modified for 184mm clutch
Clutch: Double-plate ap-racing 184mm, good for about 800nm
Head: 531-head, ported at intake & exhaust + modified
chambers, bigger stainless valves: in 46mm @ out 39mm.
Vx3 camshaft.
Compressionratio 9,3:1
Manifold: 940 turbo
Turbo: T3-04 from Sierra Cosworth,modified with larger turbine
& milled exhausthouse. Ported wastegate canal +
360° axialbearing. Vsr balansed.
Injection: Orginal Bosch LU-Jetronic. With 360cc injectors and 1,4:1
regulator.
Addon
Injection: Homemade. 3 st 800cc injectors.
Adjustable in rpm & map.
NOZ: Nx system with one nozzel. Nozzels: 25-100hp.
Normaly uses 80hp.
Inter-
cooler: Kina model in aluminium.
Boost
valve: Recirculateing model in aluminium.
Ignition: Original Renix + Ems 6 retarding box.
Plugs: Ngk br8es
Fuel: E85 (85% Ethanol + 15% Gasoline) Buy it at almoust every
gasstation in Sweden.
Sorry for the poor english
