Rear Wheels Leaning-in at the top.
Figgy
Post by Figgy »
I don't think this is normal, the top of the rear wheels/tyres lean-in towards the centre of the car, only very slightly.
What normally causes this? Wheel alignment or bent axle or ??? :?
1985 B200E 360GLT Hatch
Fuse
Post by Fuse »
If it's just slightly leaning, it's normal. Wheel angles in 300-series are that way.
Jason B
Post by Jason B »
Its fine, it should have a tiny bit of negative camber anyway but the dedion setup does sag a little with age making it slightly more pronounced. Nothing to worry about.
Figgy
Post by Figgy »
Thanks so much guys, I thought there must be something seriously worng under there. Phew :!:
carnut1100
Post by carnut1100 »
Jim's one does that too, but it is also chewing the insides of the rear tyres, so I think the camber is a little too much......
Volvos rock!
Figgy
Post by Figgy »
Sound like it is leaning in a bit too much, perhaps time for a trip to wheel alignment joint eh?
Cheers!
Figgy
Post by jtbo »
Afaik, if rear tires are leaning too much it means that one have to start looking new rear axle :shock:
