rear wheel bearing help???
kds19
Post by kds19 »
hi all
i attempted to change a rear wheel bearing on my 340 today im stuck
it was all going good i got the half shaft disconnected easy enough and the big nut that holds the hub on off easy too
but when i tried to get the hub off i just couldnt
i tried 2 sets of pullers and it broke them and i tried beating it to death with a hammer and all its done is ruin the bearing more and the hub hasnt budged
any tips????
cheer
kev
85 360 GLT drift beast
clutch kicks ahoy!!!!
Re: rear wheel bearing help???
Post by MCHUDD »
Heres how i got mine done.
Car up on ramp [head height].
One bloke with a hub puller on one side.
Another bloke underneath the car with a sledge hammer
A good half hour beating the shit out of the back of the hub.
Eventually it came loose.
kds19
Post by kds19 »
oh right aye
i dont have access to a ramp but i resorted to changing the whole axle instead lol
kev
kalyyyyyy
Post by kalyyyyyy »
i made a disk as wide as the halfshaft,i pus 3 holes in it:2 in wich 2 put the screws from the halfshaft and one bigger in the middle.i welded a bigger n ut on the hole and used a crew that fitted the nut to pull the part that needs to be taken out. I tried the hammer and it didn't work.
Ronnie
Post by Ronnie »
I now have this delightful job to do - is it really this difficult?
Also, anyone got a part number for a 1984 rear wheel bearing?
http://www.filterfeeder.eu
antiekeradio
Post by antiekeradio »
always use plenty of heat on rear wheel bearings
propane torch preferably, will loosen the Loctite thats on the splines.
afterwards, changing the bearing is also much easier when things are at temperature.
Post by 340GLT »
Heat isnt needed, if you use a volvo puller, they will come off fine. Especially if you use an air wrench.
