Project T5 360.
Re: Project T5 360.
Looking good and glad its back together again.
Does the IC pipe need sorting? looks a bit kinked in the photo
Ld50
Re: Project T5 360.
Post by Ld50 »
Speedy88 wrote:340pw Good job dude
Cheers mate :D
classicswede wrote:Looking good and glad its back together again.
Yeah I managed to straighten it out a little bit. It was a cheap one off e-bay and didn't have the nylon weaved into it so it was just floppy silicone. Funnily enough this happened today
So I managed to get 2 proper ones from a local part store and I had to re-do most of the piping between the IC and throttle body. Seems to be good now.
Anyway I think it still has a bit of a problem. I don't know I might try thicker oil or something. The lifters start getting noisy if the car sits idle for a while when warm so I think the pick up isn't sitting good. Probably need to get a sump made up since the oil pressure gauge I have either reads 0 or jumps between 1.5-4 like crazy.
I did manage to get this out of it though, didn't want to go too fast being a neighborhood and all that. http://www.youtube.com/watch?v=EgffCAFcOEE
Cheers.
Re: Project T5 360.
Post by MCHUDD »
You fairly took of there mate :lol: :lol: :lol: :lol:
sm4 sm4 sm4
Re: Project T5 360.
with the IC pipe to me it looks like the pipe needs trimming back a little to help it line up better.
The oil pressure could be something to do with the seal on the oil pump? Have a look on T5D5 forum, I'm sure it is a known problem with a known solution.
Ld50
Re: Project T5 360.
Post by Ld50 »
classicswede wrote:with the IC pipe to me it looks like the pipe needs trimming back a little to help it line up better.
Well it's weird cause it has pressure when it's cold. Even when it's been sitting for over an hour warm it still doesn't get pressure when you start it up so I don't think it's a lack of oil in the sump. I'll have a browse on the forums anyway to see but we changed all the seals and what not :?
Re: Project T5 360.
Yeah that's a bit worrying about the pressure fluctuation. The only thing I can think of is the above, unless it's a pump issue? Can't see that being temperamental though. Video looks good dude, I'm jealous.
Re: Project T5 360.
That looks amusingly fast! Fast enough to worry the suspension and brakes I'd imagine... love this project :)
Ld50
Re: Project T5 360.
Post by Ld50 »
Speedy88 wrote:Yeah that's a bit worrying about the pressure fluctuation. The only thing I can think of is the above, unless it's a pump issue? Can't see that being temperamental though. Video looks good dude, I'm jealous.
Yeah it's got me puzzled. We pulled off the sump last night, changed the pick up o-ring and checked the 2 o-rings on the edge of the sump. Tonight we pulled off the oil pump, packed it with grease and chucked it back together. Now it's getting no pressure even if it's been sitting. I think I'll be taking the sump off again tomorrow and making sure that pick up went in right. I don't think the way it sits would put the oil at enough of a slant for the pick up to start slurping in air.
Though when we started it up before we pulled the sump off and it got a bit of pressure for a while and the oil looked really aerated.
SteveP wrote:That looks amusingly fast! Fast enough to worry the suspension and brakes I'd imagine... love this project :)
Nah she'll be 'right. Yeah going to get onto them as soon as the oil circulation problem gets sorted :lol:
Re: Project T5 360.
Funnily enough, I just killed an 850 (2.5 10v NA) engine through lack of oil pressure. I suspect the pump has died. My D5 is also slow to build pressure from a cold start...as if a one-way valve has failed. Hasn't got any worse in 85k miles, and no-one seems to know the cause, so I'm just not worrying too much!
Ld50
Re: Project T5 360.
Post by Ld50 »
foggyjames wrote:Funnily enough, I just killed an 850 (2.5 10v NA) engine through lack of oil pressure. I suspect the pump has died. My D5 is also slow to build pressure from a cold start...as if a one-way valve has failed. Hasn't got any worse in 85k miles, and no-one seems to know the cause, so I'm just not worrying too much!
yeah I've searched up on it for hours and everyone says pick up or sump o rings. I mean its very unlikely both the oil pumps I have are buggered.
we got a new sealant for the rocker cover (loctite 518) and put it back together yesterday. Checked the head oil passages while we were there with an inspection camera but they look fine. It gets pressure when you rev it now so may just be a lack of oil at this point.
Either way we used the shit sealant on the block as well so may need to pull the engine out again as that could be leaking through as well.
Anyway I'll keep you guys posted.
Cheers.
Ld50
Re: Project T5 360.
Post by Ld50 »
Alright.
Got the engine out, and split the block. Big ends and mains look all good so I re sealed it with the new sealant. I'm flying out tomorrow and can't be bothered to work on it today so dad might do something while I'm on my holiday but if not I'll be getting back into it on the 6th. This time though we're going to spin the motor on the stand with a drill and going to put in another pressure sensor to see how we go.That way we can also alter the angle of the motor to see if the way it's sitting affects it at all.
Cheers.
Logan360
Re: Project T5 360.
Post by Logan360 »
I think your challenge has been laid down for ultimate sleeper.
http://www.hooning.com.au/crazy-550hp-b ... e-streets/
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
Ld50
Re: Project T5 360.
Post by Ld50 »
Logan360 wrote:I think your challenge has been laid down for ultimate sleeper.
Haha, I don't think the rear end of the old girl would handle that sort of power :lol:
Anyway, sump and pick up have been modified, we have oil pressure, but oil is pushing through the turbo into the exhaust.
As my parents have moved to another state, the car is currently at work so now I at least have a hoist to do the rest of the repairs.
The sump is leaking a fair bit as it was a shitty home job, but I have a spare sump in the boot so I'll probably get that modified properly to the same dimensions and we'll be good. I'm going to try and get the turbo return problem sorted this weekend so I can get some more footage going
sm4
Ld50
Re: Project T5 360.
Post by Ld50 »
The sump in it's current state for everyone to admire 8)
Joris
Re: Project T5 360.
Post by Joris »
That looks terrible! Doesn't match the rest of the project, which is great! :D Always thought a 5 cylinder was much longer than a redblok, but the lenght seems to be the same (bad ideas are growing now.. n/a 2.5 20v :D )
I was going through the pics and noticed on this picture there are two rods connecting the subframe to the body, have you made them yourself?
