Page 2 of 2
Posted: 10 Feb 2007 05:39 pm
by pettaw
Erm, everybody on this board seems to be saying similar....
Posted: 10 Feb 2007 06:50 pm
by A M R
what, either sellotape, bluetack, glue, or chemical metal?
oh someone forgot to say use screws...
Posted: 10 Feb 2007 10:30 pm
by Ronnie
fume wrote:Will do, when did the mk2 change to a mk3 as i thought my 87 E reg was a mk 3. I have just spoken to a bloke who thinks it could be the diff as it has had a bit of a whine. I really won't know until i have looked, if it ever stops raining!!!!!.
Change over happened around 1985, and there's a few mongrels from that era, e.g. Mk3 alloys with Mk2 wings.
Posted: 11 Feb 2007 11:09 am
by fume
Yeah, not people on this board, i really appreciate the advice, i think this repair may be beyond me, and so may have to pay someone to do it, a scary prospect if they have no idea what they are talking about as i have found.
Anyway got a chance to look last night, and when the car is in gear you can turn the prop with which it makes a clancking noise. Also with the handbrake off and the car in gear you can move the car easily.
Are the props on the 1.4 and 1.7 the same? i think they are but not sure.
Posted: 11 Feb 2007 12:08 pm
fume wrote:Are the props on the 1.4 and 1.7 the same? i think they are but not sure.
Yep - exept for the 1.4 CVT
Posted: 11 Feb 2007 05:46 pm
by pettaw
hmm, sounds like the fault is at the gearbox end then. Either the splines have rubbed smooth or the prop has seperated from the rubber doo-dahs (technical term there :P)
Posted: 14 Feb 2007 09:46 am
by fume
Having no luck finding a prop, have had to buy a another car to use!. I am going to take mine off road and take my time and fix the prop and all the other things on the list properly. I am not going to take the chance of having someone bodge it and paying them for the privilege!
Posted: 14 Feb 2007 10:57 am
Dunno where it's located, but theres a 340 breaking on ebay - might be worth contacting the seller
Posted: 14 Feb 2007 11:46 am
by fume
Thanks for the tip, i'll have a look
Posted: 15 Feb 2007 02:49 am
by shimon340
this might help!
4635103597 on ebay - propshaft!
Posted: 15 Feb 2007 09:37 am
by fume
Nice one, thank you i am hopeless at navigating ebay, i miss all the good stuff!!!
Posted: 15 Feb 2007 01:06 pm
by MJ
Go to Ebay and search for "Volvo (300*, 340*, 345*, 360*) -Haynes" (without the quotes) and you should get all 300 related stuff, but not too many Haynes manuals. Bookmark / favourite the results page and you can check back with one click. Now you shouldn't miss anything :)
Posted: 26 Mar 2007 08:41 am
by fume
Finally after all the rain and a knackered back I have had chance to have a proper look at my car. I have taken the prop off and smooth splines on the clutch end. I seem to have been quite lucky as there is a tiny bit of twisting on the clutch output shaft but not much. It might make lining up the splines on the new prop tricky but once on i think it will be fine.
It looks like its got a diff and or gearbox leak as there is thick sludge covering everything, i have drained the diff and removed the end cover to fit a new a new gasket. The problem i have now is that i can't get the filler plug out, i think someone in the past has tried to fix the leak by smearing some kind of red gasket round the end plate and over tightening the filler plug, it is actually slightly twisted.
So you guys totally right as always, i am so glad i didn't take it to a garage as it would have had a new diff and still wouldn't move anywhere!!!.
Posted: 26 Mar 2007 07:25 pm
by sven360
There's a 340 in the offer section in Norfolk that may intrest you.
