27mm Whiteline swaybar.
There is also something quite different about the 340/360 bar but I'll try and make some ilistrations to show this
This difference has nothing to do with the quality of the steel. The E-moduli of various steel varieties are virtually the same, so the stiffnesses end up the same too..Nikdev wrote:Have you guys thought about the quality of the material? for example the sway bars on a Toyota's is much thicker then Volvo`s and that's because the quality of the steel...
The difference in thickness has more relation to the length of the moment arms, which are again influenced mostly by packaging constraints.
Scuderia Rollator: Racing fridges and tractors
1988 Volvo 360 trackbeater and money eater
1983 Toyota AE86 GT-coupe - moneypit numbero dos
1985 Toyota AE86 trueno - drift only
1972 Toyota Corolla KE25 coupe
- foggyjames
I definitely think you should ask for a DORIIIIIFTOOOOOOO anti-roll bar
I've not had time to do a sketch to show the issue with comparing the 340 arb to that of a 240.
The stiffness of a anti roll bar is determined by the bar diameter and the leverage length. The leverage is the distance from where the bar mounts to the body to the link rod. This length is almost twice as long on the 340 compared to a 240!
Looking at it that way a 27mm bar is not so out of the question. From a weight point of veiw I would rather have a hollow bar for this.
For my own set up I'm still looking at the 23mm mark to give the car the kind of feel I want but the 19mm bar is going to have to do for a while yet.
