27mm is pretty big, maybe too much so, but it was a local manufacturer so i thought i'd give it a try, i'm expecting the car to show more of a understeer bias at the limit, but if it means it might keep the back wheel on the ground on the way into corners and allow me to get power down a bit earlier it'll be a good tradeoff. at the moment the front end sags and rolls so much when coming hot into a corner that the rear inner tyre has stuff all weight on it and gets no grip when the throttle is applied.
It weights about 7kgs, it's very stiff, i can't flex it at all, where as a oem one off the back of another car i can easily get a few cm flex out of, and came with poly bushes, a grease bag and generic instructions.
Will let you know how it goes when it's all fitted.
