Purple stuff left once stick on trim was taken off?PICS!!
valman
Post by valman »
hi guys, got a bit of a problem. i've had a search on here but nothing has come up.
basically when i took the side trims off and the "catalyser" badge off the back of the car the sticky stuff left over purple stains or like a coating/outline of the trims/badge i dont have pictures yet but i will have some later. any idea what this is and how i can remove it? i tried pressure washing, sticky stuff removal and no luck. even tried to scrape it off - works but scratches the paint underneath too :( tried T-cut that didnt do anything either
all help appreciated
pics of some of the purple stuff:
Image couldnt get to the sides, too much jeep in the way :lol:
L14MNP
Re: Purple stuff left once stick on trim was taken off? help
Post by L14MNP »
Try a caramel wheel that goes in a drill chuck. It's what bodyshops use. Assuming the left over stuff is glue residue or the like.
pics would be good mate. 340pw
STREETO WITHDRAWL
INTO BURNOUTSsince1982
CBA
Post by CBA »
get an abrasive sponge (the type for washing up) Scrub the "contaminant" off the lacquer.
try not to go all the way through the lacquer if you can help it.
If you don't go all the way through the lacquer (you can tell by the colour coming off on your scrubber) you can T-cut the scratched area flat and shiny.
If you do go all the way through then use a bit of new lacquer (small can £3.00 ish) to touch up the "hole" in the lacquer coat, apply a few thin coats till the level is higher than the original lacquer... like a blister around the repair area about a thou thicker than normal paint.
Once dry (3 days is usually ok ESP in the sun) use your scrubber to flatten the lacquer to the right level then use T-cut to properly shine it.
CBA wrote:get an abrasive sponge (the type for washing up) Scrub the "contaminant" off the lacquer.
I did all this by accident after de-badging with a furious credit card, and the eventual finish was very good.
CBA
Post by CBA »
Moose!!! :wink:
You know theres metal moose badges...
http://www.yourbadges.com/catalog/produ ... cts_id=284
Verr Nice. Cheap too really.
oops, my buying finger slipped.
valman
Post by valman »
WOW thanks for all the great replies, especially CBA 340pw
ill get a picture tomorrow as i only just got in from helping a friend pick up another motorbike from miles away :lol:
hopefully the sponge method will work :D
that badge does look good, but its a bit small compared to the hole the old one left i was thinking something atleast 60mm height, ill keep looking
Re: Purple stuff left once stick on trim was taken off?PICS!
Post by 340GLT »
Being as that is a straight colour and not mettalic it wont be laquered anyway. It will be 2pack topcoat paint. If you can feel it on the surface use a sheet of 2000 grit wet and dry gently with some water then some G3 polishing compound by hand.
Anything more abrasive will mark the paint.
magnumpi
Post by magnumpi »
340GLT wrote:Being as that is a straight colour and not mettalic it wont be laquered anyway. It will be 2pack topcoat paint. If you can feel it on the surface use a sheet of 2000 grit wet and dry gently with some water then some G3 polishing compound by hand.
I did mine in a similar fashion when i changed my Volvo badge on the right of the boot. That left a thick foam type sticky mess, which i scrapped back as far as possible with my nail lol, then used a small bit of white spirit on a cloth.
As Adam has suggested i then used a bit of G4 on a damp cloth and it buffed up that area. Once i had finished thats the only part of the boot with no orange peel, so it looks like they could have made a better job at the factory :lol:
CBA
Post by CBA »
sandpaper is too fast, i'd be far happier with a scouring pad instead of emery - in fact, I would T-cut it for about 5 minutes seeing it's not too bad should clean it right up. hard coat wax on top afterwards... dont skimp on wax.
