Being as techical as a very un-technical thing, I am looking for a bit of advice.
Is moving horn function from the wheel to a dash mounted push switch as easy as Im imagining?
Anyone want to break it down into instructions that even a monkey could follow?
Off Wheel Horniness advice.
- volvodspec
Re: Off Wheel Horniness advice.
yes very well possible!
if you take the panel under the steering wheel (where choke and ignition switch is) you see a brown and a red wire coming from the steering hub; you can simply take these and rerout them to a switch
a switch with springed return is preffered for this though
Yup, already got a spring return switch ready to go in.volvodspec wrote:yes very well possible!
Listen for the explosion Anjo.
Im gonna play with wires.
