Taking apart the manual tranny from a b200
Took my parts 360 apart a week ago and i''ve been stuck with the long ass bellhousing transmission thingy.
got the bellhousing off but i'm unsure where to take to bolts out to remove the long bit to the tranny itself. any tips on too making this thing sorter so i can actually store it somewhere safe
764 Turbo 86'|Volvo 144 72|Volvo 360 86'||Volvo 360 GLS 85'|242 77"|
Website: http://www.brick-autosport.com
Facebook: http://www.facebook.com/pages/Brick-Aut ... 98?sk=wall"
- 340GLT
Re: Taking apart the manual tranny from a b200
Under the rear of the torque tube us a pair of rubber bungs. Remove these and you should be able to see the coupling from shaft to box inside. You may need turn the shaft to get the bolts lined up with the holes. Remove the rear bolt completely then remove the 4bolts to the transmission and the gear linkage.
Thanks buddy i will try that tomorrow!
Got this far, seems like its stuck on the gear select pipe connection
right i found the rubbers on the box, moved the whole thing to far to get near the bolt in there..
thanks guys i know what to do now.. just have to find a way to move it all back in plae
No need to take the front of the gearbox off, just remove the torque tube now. Is it stuck? did you completely remove the drive shaft clamp bolt inside the tube behind the rubber bungs? (they are not on the gearbox). If not its possible you have shifted the drive shaft, but it can just be hammered or pushed back with a bearing puller.
taped it all the way back but i still dont see where i can undo anything?
- volvodspec
ff de krukas ronddraaien Boris, dan zie je de inbuskopjes vanzelf zitten
You are nearly there, looks like you just need to turn the drive shaft to see the bolts. It probably needs to be in neutral or the clutch pushed in, or just turn the engine on the crank pulley bolt.
right on! got it off, thank god the gear was in nutrual, shifter is already off too
should i take the axle off the box too for storage of leave it on just remove the arms?
mrborrie wrote:right on! got it off, thank god the gear was in nutrual, shifter is already off too
What axle? I thought you have already removed the De-dion tube Axle. Can't think of what else you might call an axle.
I suppose normal storage would entail removing the CV joints drive shafts from the diff and wheel hubs. You would want to keep the diff+gearbox together to keep the oil in.
