Diff compatibility 1.7/2.0
Guys, will a diff from a 340 1.7 go in to a 360 2.0? please let me know as i don't want to buy it and it not work
- 340GLT
Re: Diff compatibility 1.7/2.0
The diff unit itself is the same, although replacing the entire differential unit minus the box is your easiest option. But yes it will fit.
If operation V22, V23 and V24 of this http://www.volvo300mania.com/technical/ ... ission.pdf doesn't scare you, it's not something you should try.
If you feel suitably scared then it's wise to still not do it
This (and having bores in blocks cut and honed) are the two single jobs that I would pay someone to do on a car. Huge amounts of old skool white coat and sucking through moustache needed.
As Adam says, remove the unit with casing and do a straight swap if you can, that way it's all clocked in (apart from the wear and tear on it obv..)
