Spring Cups
Evoman
Spring Cups
Post by Evoman »
Ive been looking but im hoping someone can just point me straught to some spring cups please
cheers chris
Re: Spring Cups
Post by trabitom99 »
http://hadrian.dominohosting.biz/hadria ... 9D007885F4
If the link doesn't work, click your way through
http://hadrian.dominohosting.biz/hadria ... f/MakeList
The part is called "suspension seat".
Evoman
Re: Spring Cups
Post by Evoman »
thanks tom BUT i think i have one side with a hadrain cup and it was suggested the reason I have the problem is becuase hadrain are shit. whats your opinion?
Re: Spring Cups
My opinion is:
#1 a new strut is better of course!
#2 Klokkerholm (who supplies Hadrian) is the only manufacturer AFAIK of weld-on spring cups for the V300, so good or no good you don't have much of a choice ;-). Mine have lasted a year and a half, so far, but I'll be fitting new struts soon - definitely better in the long term.
Evoman
Re: Spring Cups
Post by Evoman »
ye my long term plan is to try and make some coilovers. But ye the those spring cups seem the only option.
thanks, ill get some ordered in time :)
Re: Spring Cups
Post by bogbasic »
Been running my 360 for 5 years on replacement spring cups that were fitted to both sides in 2006. Its the skill of the welder that does it ;-)
Re: Spring Cups
I think you'd said it in a nutshell, bogbasic. It's not the replacement cup that will fail in time, more the area where the weld meets the strut "leg". So if it's done properly, there's no reason why it shouldn't last as long as the rest of the car. After all, the cups were welded on in the factory too.
Re: Spring Cups
Post by filthyjohn »
A half decent weld will be stronger than the steel around it, so as long as you paint it well after welding it should stay rust free for a while.
Evoman
Re: Spring Cups
Post by Evoman »
I think a the momment my plan is to press ahead with making coilovers, as i can adjust the ride height to suit how i feel abit. Hopfully going to strip some legs down from j340glt, which is good adam to let me :)
