340 running badly 1.7
i have just replaced the carb with rebuild kit and floats on my 1.7 now revs fine and drives ok but hunts on idle and if you give the car a blip on the throttle when you let off it wont idle and cuts out until you start then car again any help would be great thanks kyle
Re: 340 running badly 1.7
mine had this problem a week or two ago and it turned out to be that the base plate of the carb was warped so i took it off draw filed it and made a new gasket (cornflakes box
) and it seems to be running well now.... hope that mightve helped
